Karcher 2500 Psi Pressure Washer with Honda Engine G 2500 Ph
Problem for Karcher 2500 Psi Pressure Washer with Honda Engine G 2500...
Can you show me the unloader valve?
By cathlabjul on Nov 08, 2009
Can you show me the unloader valve? I have a Karcher 2501
Best Solution
posted on Nov 09, 2009
Very Helpful)
twinman007
Rank: Guru
Rating: 89%, 34 votes
look for a black plastic cover with a silver snap on top; pry off the silver snap and lift off the plastic cover; next remove the two torx screws on the top plate then pull out the piston inside - if unable to lift out, start unit and watch it pop out - coat piston with lithium grease and reinstall
hope this helps
if it does please vote
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank you so much. Started the unit and it sure did pop out. Greased all parts and now I have a working power washer and I did it myself. " - cathlabjul
Popular Solutions for Karcher 2500 Psi Pressure
Questions and Unsolved Problems for Karcher 2500 Psi Pressure
Do you recommend Karcher 2500 Psi Pressure Washer with Honda Engine G 2500 Ph?
Answer
Answer
gas is leaking into the oil tank on a craftsman pressure washer. it will do this while it is running... (More)
Answer
engine will not turn-over. It is a Honda 11 HP, OHV on a Karcher Pressure Washer. It was running... (More)
Answer
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up ,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Karcher 2500 Psi Pressure...:
Top Pressure Washer Experts
Rank: Guru Guru
Solutions: 3951
Experience: ten years experience,school trained,own business
Ask Me
Find more Pressure Washer Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
