Question about Motorola Mobility RAZR V3
Phone stuck on windows mobile screen
Phone stuck on mobile windows screen
screen appears when phone is opened but want change when i press any keys will switch on & off & accept calls
    Brigadier General:
  • 7,752 Answers
You need to have the flexcable replaced.
Posted on Jan 06, 2008
6ya staff
SOURCE:
How do I connect my Matrix m1 mobile phone to the internet?
How to Use the Pantech Matrix for the Internet1.Press the "Menu" key on your Pantech Matrix and click "Settings.
2.Click "Connections" and highlight "Modem Link." Press the "OK" key. Turn the modem link settings to "Inactive." Press the "End" key to exit to the phone's standby screen. 3.Download and install ActiveSync on your computer if the operating system is Windows XP. If you have a later version, download and install Windows Mobile Device Center. Follow the on-screen prompts to properly set up the program. 4. Press the "Menu" key on the Matrix and click "Settings." Scroll down to "Connection" and press the "OK" key. Click "USB" to "PC." 5. Open ActiveSync or Windows Mobile Device Center. Click "Device Settings." Click "Internet Sharing" under the "Programs" tab of the program. 6.Select "USB" from the drop-down menu under "PC Connection." Select "AT&T" from the "Network Connection" drop-down menu. 7.Click "Connect" and connect the Matrix to the computer using a USB cable. A status message of "Connected" will appear in the program's window when the connection is established.
Jul 21, 2011 | Pantech Matrix Cell Phone
Tip
Nokia formating tips
Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Nokia phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
on Mar 10, 2010 | Cell Phones
How to format n72 cellphone not memory card only cellphone?
How to Format Nokia N72 & NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Nokia phone.
Aug 05, 2010 | Nokia N72 Cellular Phone
My Nokia 5130 Xpressmusic phone has a problem. It says "Theme Corrupted. Unable to open." I've already tried the *#7780# thingy, or the Restore Factory Settings, but to no avail. How can i solve it? Thanks...
Nokia Phone1. Switch off your Nokia phone. 2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key. 3. While holding these buttons, press the power button and switch on the phone. 4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message. Method 2: Hard Format of Nokia Mobile Phone1. Switch off your Nokia phone 2. Now Press following key sequence *#7370# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message. Method 3: Soft Reset of Nokia Mobile Phone1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message. Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting regards aniruddh
May 26, 2010 | Nokia 5130 Cellular Phone
How can me format my mobile telephone ? (Nokia N95 8GB)
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones. Method 1: Three Finger Reset for Nokia Phone1. Switch off your Nokia phone.
May 17, 2010 | Nokia N95 Cellular Phone
Spice d 1100 wont start need format code
If your device running on Microsoft Windows Operating System
Hold both soft keys press power at a time.
if you have stylus hole then poke in it with stylus pen.
try this, may work for you :)
Sep 24, 2009 | Cell Phones
The screen appears black when i press the keys.. what is the problem of it?
if it appear only when you are pressing a toutch key you must change your toutch pad
Aug 17, 2009 | Sony Ericsson K850i Mobile Phone
My snom 300 is dialling letters instead of numbers how do I fix
Pick up the handset and press down on the direction button until the display reads "123" instead of "ABC" or "abc"
Oloff
Nov 25, 2008 | Snom 300 IP Phone
Dash stuck on opening TMobile screen
The Windows Mobile installation may be corrupted.
The only way to fix that problem is by re-installing the windows software on the phone.
You can get the software for the T-mobile dash at the following link: http://www.t-mobile.com/wmupgrade/
Be warned that if you use this method most of the data on the phone will be lost, like text messages and etc. Your contacts should be fine as the are stored on the SIM Card and if you have been syncing your contacts with your PC then they should get loaded when you do the up
Jul 04, 2008 | T-Mobile Dash Smartphone
Dash stuck on the green screen
do a sw reset. turn the phone off, press and hold the soft keys (buttons with the lines on them above the home key and back arrow key) and hold it down.....press the power button while you are doing that until the white t-mobile screen will come on, then instead of going to the green windows mobile screen, a black screen with white writing......press the green button....it will get you in your phone but it will erase your info as a result....
Nov 19, 2007 | T-Mobile Dash Smartphone
Motorola Mobility RAZR V3 Logo
96 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
