Your Action Replay DS hardware may require resetting if you are experiencing any of the following problems:
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicolored bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes.
* You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
1. With your console powered off insert the Action Replay DS
2. Hold down buttons A+B
3. Turn your console on
4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
1) Open Code manager and insert your AR USB cord with the AR itself in the DS slot make sure the DS is off.
2) Turn on your DS so that on the PC screen the Code Manager is listing the Games already on the AR
3) Then when the games are on the screen decide what game you want to add codes to, Makesure there is a copy of that game in the Default code list with the cheats you already have on there if the game is not in a code list in the slot "My codelists" drag the game into a code list, What should happen is the top DS screen will say Reading, then the games master code same should be on the PC screen under the new box "Process"
4) On the code list where you have just dragged the game to the game should be in there open it up by clicking the little + next to it.
5) In that game file there should be all the cheats you have prevously added. right click on the game tile and hit add new cheat, Cheat details should appear so add a name and copy and paste the code then hit okay afterwards delete the file on the AR NDS code list and copy and paste the new one so that when it is open it will have all your old cheats and the new ones.
what you have to do is goto the game in your my codelist and then open that up with the + symobol and then right click and add new code then close the game by pressing the + button again then left click on the game and hold it down and drag it to the left side to your ds code list to the action replay there and it will update.
The problem is that the games or the ds action replay game slot is unfunctional. If it is the AR, just start up the action replay and eject it. Then put the game in, and start playing. To enter codes, leave the AR in and enter the codes. after you enter codes, the AR will save atomaticly.
