Ice maker on GE Profile side by side refrigerator/freezer will not quit making ice.It's like the Energizer Bunny,it just keeps going and going and going.HELP...
It may be turned off. Check the Ice
maker shutoff arm located at the top of the ice bin. Look for the wire
along the right side of the ice maker that looks a bit like a coat
hanger. If the wire is in the raised position, the ice maker is turned
off. If so, simply lower the wire.
Is
there water in the ice cube tray? If not check for water to the water
valve. If you have water then it could be either a failed fill valve or
ice maker control module is not activating the water valve.
Check for pinched water supply line (behind the fridge)
Do
you have an inline water filter? If so, when was it changed last? To
test if it is plugged, check for water both before and after the filter
system.
Sometimes
the water inlet tube that directs water into the ice cube tray freezes
over; this can often be thawed out by simply using a hair blow dryer
and warming the area (be careful not to overheat the plastics as they
can warp or crack). Then adjust the freezer to a slightly warmer
setting and make sure water is not constantly dripping from the inlet
tube, as it will only freeze over again.
Need a new refrigerator after only 8+ years from Kennmore -- have not been happy with this brand on...
(More)
Need a new refrigerator after only 8+ years from Kennmore -- have not been happy with this brand on the last 2 refrigerators. Would like a large capacity and efficient refrigerator with a reputable for being trouble free. Thanks.
