Question about MSI Wireless-G RG54G3 Router
Help me please
I'm using MSI Wireless-G RG54G3 Router for my home network. A device which support wan is connected to the router. At the moment i am able to connect to this device from the internal network only. My problem is how can i set the router to access this device from any internet connection outside the network.
    Novelist:
  • 139 Answers
Two separate solutions are needed.
First, you will need to ask your ISP (Internet Service Provider) to assign a "fixed IP address" to your Internet connection. Your ISP typically assigns addresses to home users out of a large "pool" of addresses that are shared among several customers. Because of this, your home network address is not always the same. Most ISP's charge an extra fee to always keep your address the same.
The second task is to configure the firewall function in your router so it will pass connections through from the WAN to the device inside your network. The procedure to do this should be included in the instruction manual for your router.
Posted on Jan 11, 2008
How do i find the wap2 ket or network key
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
May 22, 2010 | MSI Wireless-G RG54G3 Router
I have connected MSI RG54G3 to a caple and it's not give me ip and internet access
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
To access the Internet you need to connect the DSL or cable modem to the WAN (Internet) port on the wireless router.
Dec 01, 2009 | MSI Wireless-G RG54G3 Router
How can you set up a network of 4 computers with a RG54G3 router?
*** configurez router ,ca nu am cd la el nici manual rg54g3 msi
Feb 26, 2009 | MSI Wireless-G RG54G3 Router
How do i encrypt my system
Hi, I will lend a hand if I can.
There are four basic steps to set up wireless security:
1) Login to your router
2) Change the router login password/username
3) Change the network name, or SSID
4) Enable WPA encryption
As you only want encryption, I will go straight to step 4. The following is based on the manual for the MSI RG54G3.
Here are the details:
1. Login to your router.
2. Go to Setup> Wireless.
3.
Select WPA-PSK - strictly speaking the correct option depends on your wireless adapter. However, this is usually a good choice to start with. You may see one or more new options pop up. Select ASCII if necessary.
4.
Under ‘Pre-Share Key’ you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappynEWYeartoyou8899). It is case sensitive.
5. Note down the ‘Pre-share key’, also called the network key, carefully. You will need this to connect wirelessly. (The network key may also be called a WPA shared key, PSK, pre-shared key, passphrase, authentication key). Click ‘Save’ when finished.
When you next attempt to connect wirelessly, you are asked for the network key you've just set up. If all goes well, you can then save this and will connect automatically in future.
Hope this helps, but if it is not clear or doesn't work, please come back to Fixya. Good luck.
Jan 05, 2009 | MSI Wireless-G RG54G3 Router
Wireless conncection
depending on who your ISP is, you need an ethernet cable coming from the modem into the WAN/Internet port on back of router. Once that is in you can try to connect wirelessly using the settings your router is setup for :
SSID/network name
encryption type
encryption key/passkey/passphrase
-- this part is dependent on above setting
wireless channel
Jul 08, 2008 | MSI Wireless-G RG54G3 Router
MSI wireless G RG60G fast bliking wan.
hello!
fast blinking wan light may indicates that it receiving or sending data. try the ff and see if this may work:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
Apr 24, 2008 | MSI Wireless-G RG54G3 Router
WIFI Connection
Ensure the router is able to broadcast b + g radio signals, select it to do both rather than just one or the other.
Mar 15, 2008 | MSI Wireless-G RG54G3 Router
Msi rg54g3 wireless router
Cable modem or DSL? If cable modem without phone service, modem power has to be unplugged 2 minutes before the router is connected in order to release the mac address from memory. If cable modem with phone service, same thing applies, but battery backup must also be disconnected.
DSL modem may require PPPoE setup into router.
Mar 09, 2008 | MSI Wireless-G RG54G3 Router
MSI rg54g3 ieee802.11g vista driver
Generally you do not install a router onto a PC you connect to a router with a wire using a network adapter or wirelessly with a wireless adapter. Can you any of the following you have identify you make and model of PC, make and model of add-on adapter card? Then I may be able to assist you in determining if a driver exists for the device attached to your computer intended to communicate with the identified router.
Thanks
Dec 09, 2007 | MSI Wireless-G RG54G3 Router
MSI RG54G3 router cannot connect to internet
i hink this issue has been resolved by you by now. if it perists do lemme know about it. it seems yor router is not configured properly regarding the authentication like user name n password. n i think the MAC address spoofing is also into the picture , mostly MAC add spoofing is done on cable connections but sometimes it can be also used with the "user id n password" together. For any other issue- chat with me on msn or yahoo messenger my id is samrat101 on both the messngers samrat
Aug 12, 2006 | MSI Wireless-G RG54G3 Router
MSI Wireless-G RG54G3 Router Logo
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
