Video Game Consoles
Problem for Microsoft Video Game Consoles
Generic problem for all Microsoft Video Game Consoles
3 red rings
By shelbarrett on Nov 08, 2009
3 red rings
Best Solution
posted on Nov 08, 2009
Very Helpful)
cooke2518
Rank: Guru  Video Games  Expert
Rating: 86%, 28 votes
e74 or rrod error means that there is an hardware issue.
What you need to do is a very simple and cheap repair.
look on ebay for x clamp repair kits, these are just a few bucks and most sellers include a good guide in how to do the mod/fix.
what causes the rrod or e74 error is the X shape clamp on the underside or the mother board bending and mis-shaping causing the ball soldering on the gpu/cpu slightly melting and forming hairline cracks in the solder.
The x-clamp kit will apply more pressure to the gpu/cpu and a little trick of disconnecting the fans and turning on the xbox and allowing it to overheat will re melt the solder ball joints to fill the hairline cracks.
Depending on which chip is the issue you may also need a 2000 watt heat gun instead of using the over heating method (the gpu chip).
Replacing the heat pads on the heat sink with thermal paste which comes with the kit will keep the gpu/cpu cooler and you wont have this issue again.
Please make sure you buy the kit which comes with heat treated nylon washers as the steel spring washes fail!.
The repair takes around 1-2 hours
I hope this helps in fixing you xbox.
Bewarned that opening your console voids any warranty on it, i would recommend contacting microsoft to see if it is still under warrenty as this could be a free fix by them
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Video Game Consoles
Questions and Unsolved Problems for Video Game Consoles
Answer
i inserted my ssid,ip,subnetmask,gatewaypri.DNSsec.DNS.when i tap on test connection,it connets my... (More)
Answer
A warning keep popping up: EA servers could not be established. I have restarted my consult and... (More)
Answer
Habe bereits vor ca. 3 Wochen das Problem telefonisch mitgeteilt. Mir wurde zugesichert, dass.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
