Question about Gigabyte GA-K8VT800 Motherboard
No sound I cannot get sound to work.driver installed,dxdiag picks up fault but does not say how to fix??? Device mngr show device working properly.Ideas pls??
  • 1,006 Answers
You can choice here:
Posted on Jan 06, 2008
No sound heard
Hello dnagodh
First, test your speakers by connecting them to another sound device like CD/DVD player or a similar device. If you can hear sounds from the speakers, they are fine. Next, connect the speakers back to the computer. Make sure that you plug them into the right colored jack at the back. The speaker pin should be plugged into the green jack at the back of the computer.
Now, if you can't see the speaker icon in the system tray, you may need to enable it from the Control Panel. From the Control Panel, double-click "Sound and Audio Devices" and check the box that says "Place volume icon in the taskbar.
Next, run the following command from the Start -> Run box and then press Enter: dxdiag
Click on the Sound tab and you can see the details of your sound card. You can also test your sound card from this tab. Note the name of the sound card driver, on paper. If you can't even see the sound driver name, the driver is not installed or not installed properly.
The easiest thing that you can do now is to do a system restore, using the System Restore utility.
Here's a link about how to use the system restore utility on Windows XP:
Here's a link about how to use system restore from Windows Vista:
If System Restore didn't make the sound work, do the following:
Start the Device Manager (Right-click My Computer -> Properties -> Hardware -> Device Manager) In Device Manager, Click the + sign next to "Sound, video and game controllers". See that the sound driver that you noted above, is listed.
Now, double click the item in that list that has the same name as you saw in dxdiag's sound tab. Does Device Manager say that the device is working properly? If Device Manager says that the audio device is not working properly, or if there is a yellow exclamation mark next to the device, or if it says that the drivers are not installed for this device, install the drivers from the CDs or from the computer manufacturer's website. However, there's an easier way to do this, as given below.
Here's the easy way to get or update your sound drivers:
You could try to use this driver scanning tool, which scans the computer for needed drivers and has an option to automatically retrieve them for you.
You can download this free tool from here:
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
It's also possible that the drivers are there but the sound card was displaced a bit from it's slot (in case you have a separate sound card on your motherboard, and not a built-in one).
If you suspect this, you should open up the computer and pull out the card. Then, re-insert it firmly into the slot or try another slot if you have another one free. Make sure to tighten the screw to fix the card to the case, and put one there, if it's missing. Here's a youtube video about how to install a sound card:
If none of the above methods worked, pull out your sound card and test it in another computer. You can also try re-installing Windows and lastly try another sound card, if it still fails to work.OR at last go to near computer shop.
Hope that helps,
Dec 21, 2010 | Computers & Internet
I installed winxp on acer aspire 5720z original came with vista now i Finally got netwrk adapter correctly installed at least in device mngr no yellow! Though in network settings keeps saying disabled but...
im not sure if you can detect a certain driver you might have to go through the process
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Oct 25, 2010 | Computers & Internet
Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not...
hi, here are some solution plz try them all..
1. Have you tried updating the sound card drivers to their latest version?
Don't just check Windows Update, but the card manufacturer's website as
2. Here is a simple quick fix!!!!!!
Open the Media Player
At the top, Click on "Tools"
Select "Options"
Click on the "Devices" tab
In the list of devices, double-click on "Speakers"
Under 'audio device to use' it probably lists your sound card ...THIS IS WRONG!!! !using the selector button on the right side of the window, change this
setting to:
"Default Directsound Device" (Note that "Directsound" will show as one
This problem happens because MS never should have allowed this setting
to be changed ... it's senseless.
3. Click Start, then Run. Type dxdiag, then click OK. Choose the sound tab. You should see your device and driver there and you can even test the sound. If there is no device or driver, just install it and check it with dxdiag again.
Hope that helps,
Oct 11, 2010 | Computers & Internet
Hi, When I click Start/Run/dxdiag on my windows screen, I get this message in a window called DxDiag Error: "Error: Problem getting extra sound info, result code = 0x80070057 (Invalid Argument(s))"....
You can go to device manager and uninstall your sound card from there, To open device manager Right click Mycomputer>Properties>Hardware tab> Device manager and once you're there look for the Asus Xonar D2X and then right click on it and click uninstall and after that restart the computer and that should correct the problem......
Nov 18, 2009 | Computers & Internet
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
Sound problem
please download the drivers for your computer , from this site:
cheerup and be Happy always
Mar 25, 2008 | E-Machines eMachines Refurbished EMA...
Sound problem
you can look in device manager in control panel and look in the hardware list and see if there is any yellow exclamation marks, if so this is probably your sound device not having a driver. If you are sure there is no problem with the driver, then click start>run, then type dxdiag and press enter. Look in the sound tab and click test to see if there is a driver fault.
Sep 09, 2007 | Microsoft Windows XP Professional With...
Audio Problem
Remove the card and use system restore in accesories to see if you can restore to a time previous to installing the card. If the problem persists, you can run dxdiag, go to start>run, then type dxdiag and hit enter, go to the audio tab and it will point to the problem
Mar 17, 2007 | Dell Latitude C400 Notebook
No sound
The drivers you mention are related to your sound drivers to they are installed. Run this programme to see if there is a driver problem, click Start>Run then type 'dxdiag' and hit enter. It could be the motherboard sound chip thats failed.
Jan 27, 2007 | Dell Inspiron 6000 Notebook
Gigabyte GA-K8VT800 Motherboard Logo
79 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
