Question about Canon PIXMA MP160 All-In-One Printer
Image using Scanner White on Black..
When I scan an image on the scanner the image appears white on black (ie reversed). How do I view image as normal scanner image.
Scan are not scanning completly
Posted on May 03, 2008
Scanner does not appear to work
If you put something in and click "acquire", do you get the same white image?
Jun 08, 2015 | Office Equipment & Supplies
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    Xerox Documate 152 - Scan quality is now V.BAD!
    I would go to and look up their knowledge base. Here is a copy of data from their site related to this problem:
    Symptom: Scanned images have poor image quality, are fuzzy, unclear, or hard to read.
    Cause: There are several things that can lead to poor image quality including the scan settings, dirt on the scanner, and driver problems. Solution: Note: If you scan as a PDF file and your scans look fuzzy when viewed in PaperPort, try right clicking on the file and selecting "Open" to open them in Adobe Reader. If they display fine in Adobe Reader then there is nothing wrong with the scans, it is simply that they are not being displayed well in PaperPort.
    The following solutions can help resolve poor scan quality.
    Solution 1 - Adjust the scan settings
    Try increasing the resolution of your scan. 300 dpi to 400 dpi should be clear for most images
    • If you are scanning in Black and White, try Grayscale or Color. Some images will not display correctly in Black and White
    • You can also try adjusting the brightness and contrast
    • Note: For information on adjusting your scan settings, refer to the user guide for your scanner
    Solution 2 - Clean and Calibrate the scanner
    Note: Calibration only applies to sheetfed scanners.
    Use the link below for instructions on cleaning and calibrating (if applicable) your scanner:
    Solution 3 - Reinstall the scanner driver Select a link below for instructions on reinstalling your scanner driver:
    Jul 08, 2009 | Xerox DocuMate 152 Pass-Through Scanner
    Scanned Image is all black
    Try uninstalling and reinstall the scanner again. Try on a different computer. If even after this the problem remains, may be the there is some hardware fault (failure of light) in the scanner. How is it in color?
    S. Mohan
    Apr 09, 2009 | Canon DR-1210C Scanner
    Images scan black via flatbed or auto feed
    Check your software settings, Try Auto Brightness for scanning a white sheet.
    S. Mohan
    Nov 06, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
    When scanning color document, blue tone is present as background shade
    Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
    Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
    Scanned image only prints in black and white
    it's tricky / annoying:
    you have a preview ...
    you have some of the (3) images checked
    but also you have some of these images selected (blue outline)
    when you select (I don't mean the checking) an image you'll have to set the scanning params
    again - or check them ...
    if you select an image, and then set the params (like "color"), your scanned image will be in color
    also resolution is the same way ..
    especially after crating preview .. it'll be set to 300 Dpi
    so after seecting one for scanning - check the resolution too :)
    Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
    Documents scanned as 256 grey scale/TIFF show up as black pages.
    Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
    S. Mohan, Chennai , India
    Jan 05, 2007 | Canon DR-9080C Path-Through Scanner
    Canon PIXMA  MP160 All-In-One Printer Logo
    125 people viewed this question
    old marine
    old marine
