Hello
My name is Edo and I am IT for UN mission in Afghanistan. We
have copier Panasonic Workio DP-4530 and it is heart of our design office. We
use copier for publishing documentation, for copying and printing. We can find
any normal service in Afghanistan. The nearest place for repairing is Dubai.
I have experience with copiers and I want try to fix our
copier. Currently, our new problem is
error “clean fusser web”.
I need only if anybody have service manual in pdf or similar
format. I will be very appreciated if anybody can help us. Your any advice is welcome
as well.
Mr. Edin Husejnefendic
IT Systems Manager
Vertical Structures Unit
Afghanistan Operations Center (AGOC)
United Nations Office for Project Services (UNOPS)
House No. 6, Behind Emergency Hospital
District 10, Shar-e-Naw
Kabul, Afghanistan
Mobile: +93 0799 303-021
http://www.unops.org
Comment by lihnjo, posted on Jan 10, 2008
I found service manual with your codes for service mode. I restarted web fuser counter and now it works. Actually, each 240000 copies we have to repair and restart web fuser counter. I fixed problem temporary but I should change expendable parts.
Comment by lihnjo, posted on Jan 25, 2008
I bought service manual for DP4530. If anybody need manual contact me on lihnjo@gmail.com.
Cheers
Edin
That error, you can simply reset the counter for the fuser web. Go in to function mode (function + original size + 3 at the same time). Go to F7 for counters, find the fuser web counter and set it to 240,000 to reset it. Set any other counter alarms that go off to 0. The maintenance period is supposed to be 240k copies, but from the factory it comes set as 120k so you can change that if you want.
Comment by MitchSchaft, posted on Jan 24, 2008
Was this solution helpful? Show your Appreciation by rating it:
Let me know if you do not know how to get into the service mode of the copier. It normally is pressing the following three buttons simultaneously - Original, Function and the number 3. It may take a few tries before you get the sequence properly. Also, if it requests a password, try 0000 or 00000000 (8 zeros or 4 zeros)
Post a New problem for Panasonic Workio DP-4530 Grayscale
Email this problem
