Home | HP | DeskJet F380 All-In-One Printer | Hi My problem is tha...
HP DeskJet F380 All-In-One Printer
Problem for HP DeskJet F380 All-In-One Printer
Hi My problem is that this plastic strip has come
By hi_you50 on Nov 08, 2009
Hi My problem is that this plastic strip has come off of something and now the ink cartridges go back and forth really hard but doesn't print anything. There are little slits on each end of the strip. One end is ripped so I figure this is why it came off. I have no idea where it would go or if I can get a new one or use this one. Please help
Debbie
Comments:
Nov 08, 2009
- I have the strip that you have mentioned but I don't know where it goes. If I can put it back on I would be happy. The problem is I don't know anything about printers and so I have no idea why this would of come off or where it goes. I believe it is the little slit that is ripped that caused it to come off. If you could tell me where and how to put it back on I would appreciate it
Best Solution
posted on Nov 08, 2009
Very Helpful)
edmacias
Rank: Guru
Rating: 91%, 24 votes
Hi Debbie,
If the plastic strip is about 10mm (or ~0.4 inches) and about the with of the printer, and if you look very closely the strip is striped (with tiny very think vertical lines).. .that strip is the locator strip… The ink cartridges read that strip to know where the carriage is (ie the carriage reads/counts the strips and then it knows where it is)
Hence if the stripe is now in your possession the printer doesn’t know where the cartridges are and just keeps moving them back and fro hoping to “find them”.. sadly without that stripe you printer will work no more L
Sorry.
Ed
Comments:
Nov 14, 2009
- HI Debbie,
Apologies if I wasn't clear. The strip, if it is still intact, is held in position by to posts at each side of the printer. The strip goes horizontal (the same motion of the cartridges when printing). It goes about 1/2" above the metal cylinder that the carriage sues to travel along.
There is one hook on each side of the inside of the printer) above the main cylindrical bar) that hold the strip tense. Hope this helps.
Ed
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for HP DeskJet F380 All-In-One
Questions and Unsolved Problems for HP DeskJet F380 All-In-One
Do you recommend HP DeskJet F380 All-In-One Printer?
Answer
Answer
when i go to print the cartridge holder seems to hang up does not move, it tries to and every once... (More)
Answer
hi i'm using continous ink system f380.. the problem is the colored ink can't continous running..... (More)
Answer
i have lost the cd which came with the printer inow have anew pc how do i install
Answer
The ink of HP Deskjet F300 printer wont function
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP DeskJet F380 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
