Washing machine stops mid-cycle and full of water
I am using a fagor select FU 1047 washing machine. It stops mid-cycle, full of clothes and water. What do I do to retrieve my clothes
  • 4 more comments
  • giacomo9 Mar 23, 2009
    hi, i have the same washing machine but no user guide.do you know which programme is which?theres 12 of them.....
  • Anonymous May 02, 2009
    washing machine stops mid cycle full of water
  • Anonymous Mar 22, 2014
    In mid-cylce the electricity went off and machine now half full of water and can not get machine to turn off
  • Anonymous Mar 25, 2014
    my machine stops in mid cycle. is it on standby mode and how do i switch it off
  • Anonymous Mar 28, 2014
    water level is full
  • Anonymous Mar 31, 2014
    I have the same model as above so my problem is that I start it then half way through the cycle it stops so then I restart it then it goes the beginning it did not do the full cycle and my clothes weren't washed at all could you please tell me what the problem is thank you.
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
  • Vitor Santos Pinto Jun 12, 2013
    All that said and all is noticed as I believe that the problem lies elsewhere. Makes the auxiliary functions, taking in water and out, but does not start any program. The control panel has the lights on in the office, but there is no sign of a boot program. We have done tests with the machine empty.
Fagor dishwasher showing f6
Please check fault codes on page 70 in this manual.
http://www.fagor.co.uk/documents/LFU-65iT.pdf
F6 would mean the water is not getting heated. I am not sure which model you have but if there is only a cold water inlet connection then either heater or thermostat is faulty. If you have both hot and cold water inlet then you may have to check if hot water is getting in at right temperature. Easiest way to confirm is to run dishwasher in cold cycle (short rinse) and see if it goes through. The heater would get used in warm/ hot wash cycles and drying.
Sep 19, 2014 | Fagor Dishwashers
Fagor select fe-1046 manual
Does anyone have a manual or know where i can find a manual for a Fagor Select FU-1046 washing machine
May 17, 2012 | Washing Machines
Hi - My Whirlpool washer appears to not use enough water. Don't get me wrong, I want the machine to use low water (that's why I bought a front loader, model: WFW97HEX). However, when I stop the...
Don't pause the cycle mid cycle. The machine uses the amount of water it needs to clean the amount of clothes that are in the tub. If you pause it after the first 7 or 8 minutes, you're already past the sensing part of the cycle and likely you won't get more water for the additional clothes.
Also, the clothes don't need to be soaking wet or wet enough to wring out. These new HE machines mix the detergent with water and then spray that detergent solution onto your clothes. Then the clothes against clothes rubbing with that solution already coating the clothes is how the machines clean better! It is a very similar process to when you pretreat your clothes with Shout of Spray and Wash. You spray the clothes and then rub the short against itself. Now the Whirlpool machines are doing this for you!
Aug 30, 2011 | Whirlpool WFW97HEX Washer
We have a fagor washing machine (model - FU-1148-IT) and cannot find a user manual for it anywhere, please help as we have a baby and it's not cleaning his clothes on the setting we are using
Have it on Number 3 for the wash, 5 is the best spin. It gets smelly quite quickly, so wash the drawer alot, and get the mould out from ALL the inside of teh drawer compartment, and wash it at 90 with washing machine service powder (Asda 3.50!)
Nov 26, 2010 | Fagor Washing Machines
Hi everybody, I have a SpeedQueen Washing machine that does not complete the whole cycle while washing, it stops at the mid-cycle. What could be the cause? Thanks
It could be the heater element, if the wash water does not reach the temp selected by you within a certain time period, the w/m could abort the cycle.
The pump or outlet hoses could be blocked and the w/m cannot expel the waste water between rinses.( This would be if the machine stops and is still full of water). Try running a cold wash cycle and this should confirm if it is the element as it will complete the cycle ok.
Hope this help
Jul 08, 2010 | Washing Machines
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
Jul 14, 2009 | Washing Machines
Programmes for Fagor Select FU-1047
Sadly I don't have the answer, I have the same predicament as you! I don't suppose you have had any luck finding one have you?
Mar 23, 2009 | Washing Machines
Washing Machines Logo
3,107 people viewed this question
Top Washing Machines Experts
