Home | Sony | KP-51WS500 51 in. Rear Projection Television | Colors so far out of ali...
Sony KP-51WS500 51 in. Rear Projection Television
Problem for Sony KP-51WS500 51 in. Rear Projection Television
Colors so far out of alignment
By e_chase on Nov 08, 2009
Colors so far out of alignment "Magic Focus" aborts. Or, if it goes all the way through the screen will loose focus and colors will "drift" after a while and need to be "Magic Focused" again. What's up?
Best Solution
posted on Nov 08, 2009
Very Helpful)
SD Tech
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 97%, 854 votes
IF convergence is changing there are only a few possible reasons.
I would suggest first if you have the original Sony remote go into the customer menu and try to manually adjust the convergence---if it adjusts there you may not have a problem unless it still changes after time.
If you still have the problem only two possible reasons---one of the two STK-392-560 convergence chips this model uses is intermittent; you would have to replace both chips to find out.
You can buy a pair of the chips on Ebay for less than 14 dollars plus shipping------it depends if you are able to replace them yourself---I can give you instructions on how to do this in this set and what you will need.
The only other possible reason for this is you may have a bad DCU----digital convergence unit---it stores all the convergence adjustments---it is fairly expensive and may only be available as a rebuild.
LET ME KNOW IF YOU HAVE ANY QUESTIONS-I am here to help.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Sony KP-51WS500 51 in. Rear
Questions and Unsolved Problems for Sony KP-51WS500 51 in. Rear
Do you recommend Sony KP-51WS500 51 in. Rear Projection Television?
Answer
Answer
colors have separated pink and green shadows picture blurry is it worth fixing?
Answer
Standby light is on all the time and thus there is no picture
Answer
TV goes on and then goes off and red light blinks
Answer
how do i tell if the tubes are goin bad in my sony rear projection tv
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-51WS500 51 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
