Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Problem for Black & Decker 19" Electric Lawnhog Mulching Mower with...
I have an 24V electric mower.\i charge it
By codru3 on Nov 08, 2009
I have an 24V electric mower.i charge it yesterday, now shows that is charged but doesn't start!!!
Solution #1
posted on Nov 10, 2009
Not Rated)
n2vrh
Rank: Wiz
Rating: 94%, 5 votes
Either the connector between the battries and the mower are bad or the starter switch is bad, you know the wires between the batterries and the connector are good because you said the batterries charged just fine, so either between the connector and the motors, or the key switch has a break in its continuity, easiest way to test is connect the batterries directly to the motor to see if it works if it does connect before the start switch then after the connector the before the connector and keep moving up the connection wires until you fine where the problem is. Hope This Helps Don
Was this helpful?
Yes
No
Popular Solutions for Black & Decker 19" Electric
Questions and Unsolved Problems for Black & Decker 19" Electric
Do you recommend Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag?
Answer
Answer
I want to funish the Catcher (bag) for this mm525 3.5HP type 2-12 black&decker Lawn Mower... (More)
Answer
Thanks to you guys I figured out how to wire up the switch, but the wires were all disconnected on... (More)
Answer
The breaker (Short Stop 24v F09 40A) is faulty. I got a replacement but when it arrived I findit is... (More)
Answer
I have a Black&Decker cordless mower. Model CMM 1200. When I plug in the wall mounted... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Black & Decker 19" Electric...:
Top Riding Mower and Gar... Experts
Rank: Guru Guru
Solutions: 3968
Experience: ten years experience,school trained,own business
Ask Me
Find more Riding Mower and Gar... Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
