Panasonic PT-47WX49 47 in. Rear Projection Television
Problem for Panasonic PT-47WX49 47 in. Rear Projection Television
Is this tv a 3d screen becuz it looks kinda
By c323206 on Nov 08, 2009
is this tv a 3d screen becuz it looks kinda bluryy????
Best Solution
posted on Nov 08, 2009
Very Helpful)
SD Tech
Rank: Guru  Panasonic Televisions & Videos  Expert
Rating: 97%, 965 votes
If you have gone into the customer menu and CONVERGENCE is skewed and will not adjust:
One or both of the two STK-392-110 convergence chips that this set uses are bad.
The chips are about 2 1 /2 inches wide by 1 1/2 inches tall and are black in color. They are mounted on metal heat sinks with fins and are side by side--they will have the Stk-392-110 number printed on them in white letters.
If you locate them take a good look at all the light blue resistors in front of them--most are marked 2.2 ohms---look for any that are white or discolored in the middle---if you find one or more YOU HAVE FOUND YOUR PROBLEM.
BOTH chips and any bad resistors need to be replaced and the set adjusted. If you can do this repair you can save a lot of money as you can buy both chips (a pair) on Ebay for about 12 dollars plus shipping.
I have start to finish instructions for this repair on this type of set.
If you cannot do this repair yourself, shop around your area--most shops charge 300-400 for this kind of repair--I do them here for 200-250 and have done hundreds of them.
If they say it has to go to the shop--keep looking as any good tech can do this repair in your home in about 1 hour.
If you have any questions or need advice reply to this posting here OR check out all my many solutions here for more information concerning what I have told you.
I am here to help people. If this information was helpful rate this solution as I do this here for free.
Regards, SD TECH
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Panasonic PT-47WX49 47 in.
Questions and Unsolved Problems for Panasonic PT-47WX49 47 in.
Do you recommend Panasonic PT-47WX49 47 in. Rear Projection Television?
Answer
Answer
I have blue dots on a panasonic pt61lcx35 tv...What is the problem
Answer
hello - the tv power turns on but 5 seconds later the power shuts off and will not turn back on. If... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
