Home | Hotpoint | Aquarius WF000 / WF000G / WF000T Front Loa... | Very noisy when spi...
Hotpoint Aquarius WF000 / WF000G / WF000T Front Load Washer
Problem for Hotpoint Aquarius WF000 / WF000G / WF000T Front Load...
Very noisy when spinning -is there a spare part to
By lee_armstron on Nov 08, 2009
Hotpoint aquarius wf000 which is very noisy when spinning -is there a spare part to fix the noise - everything else is working fine
Solution #1
posted on Nov 08, 2009
Not Rated)
Samyfam
Rank: Guru
Rating: 92%, 84 votes
This is most likely the drum bearings failing.
Quite often drum bearing failure is caused by a faulty drum shaft seal allowing a small amount of water through and in to the bearings. The bearings then start to rust and this accelertes how quickly they deteriorate.
Replacing a drum bearing requires well above average DIY skills, so unless you feel you can do it, can get hold of a tech manual, and can find a supplier for the bearings, it's time to get a quote from an engineer.
Was this helpful?
Yes
No
Solution #2
Not Rated)
localwonder
Rank: Guru  Hotpoint Washers & Dryers  Expert
Rating: 92%, 2774 votes
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
NOTE_ Verify That the shipping system including shipping bolts, spacers and cables are removed. This is a common issue when a new washer is installed.
Was this helpful?
Yes
No
Popular Solutions for Hotpoint Aquarius WF000 /
Questions and Unsolved Problems for Hotpoint Aquarius WF000 /
Do you recommend Hotpoint Aquarius WF000 / WF000G / WF000T Front Load Washer?
Answer
Answer
Wf540, wont start, cant hear water filling machine, display shows "Door"
Answer
I have a hotpoint aquarius WF540 machine. It has stopped working and the Wash Enhance &... (More)
Answer
washing machine, will not spin all the rest of the cycle seems fine, clothes still very wet at the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hotpoint Aquarius WF000 /...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14739
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
