Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
I am not getting any water into my Ing...
By r_theriaulta on Nov 08, 2009
I am not getting any water into my Inglis scour master. It is a built in model. Any solutions???
Solution #1
posted on Nov 08, 2009
Not Rated)
Samyfam
Rank: Guru
Rating: 92%, 90 votes
Have you checked the inlet filters on the water hoses ?
If you unscrew the water hoses from the machine, and look inside the connections on the machine, you should see the filters - they are usually a plastic "cage" supporting a gauze or fine mesh. These can be pulled out (you may need tweezers or fine nosed pliers) and washed under a running tap.
If this doesnt cure it, check that the water supplies where the hoses connect to your house plumbing are actually fully on and flowing properly, and as yours is a built in model, that when the machine is pushed back in to it's housing the water hoses are not being kinked or trapped to the point the water cant flow properly.
Otherwise, there is probably a fault with the solenoid valve(s) on the machine that controls the flow of water in to your machine.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
it doesn't appear that the top or upper rack washing arms are moving.
Answer
what is the name of the part that screws the spray arm to the lower venturi
Answer
My dishwasher runs, and it's clear that water is getting into it, but it doesn't get anything clean.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
