lubbarlubab, Looks like you will need to get a power supply repaired/replaced in your unit. Before you call out the service guy, you should spend 30-40minutes at YOUTUBE and view some "LCD-TV repair" videos and also videos of "LCD monitor repair" and LEARN what are the most common components that are causing this plague of "BLACK SCREEN of DEATH" to disrupt your life. If the "cold-cathode-fluorescent-lamps" fail to light-up due to a failure of a single or multiple $2 parts on a power supply board you have a black screen!! This problem is also very common to LCD computer monitors. Try to view a vid by someone called "cal22583" who did his own repair to a Philips 42" or 50" unit. If this was of some help please rate on fixya.
Bye for now. 12fixlouie
My Zenith flat screen 20" model L20V26C is in Key Lock mode and I can't get it to move even...
(More)
My Zenith flat screen 20" model L20V26C is in Key Lock mode and I can't get it to move even with a remote. I was trying to access parental controls and the key lock got activated instead. Now it is locked on one channel and we can't even turn it off, we have to unplug it completely.
I have a Zenith P-IV PC with Windows XP Media Center 2005 & 19'' CRT Monitor which is around...
(More)
I have a Zenith P-IV PC with Windows XP Media Center 2005 & 19'' CRT Monitor which is around 3years old. Recently my monitor started displaying only a thin bright horizontal line in the center of the monitor. Initially if I banged the monitor lightly, the display would become normal. But now nothing helps. I checked the connections of all the cables, they are fine. I removed & reconnected them, but with no positive result. The PC seems to work fine, as the color of the line changes as per the change in display on the screen. My current wallpaper is green colored, so it displays a green line. As soon as the screensaver starts it displays the color of screen saver. Is my monitor repairable or is it dead. Please Help Me.
When I turn-on the power button to my 13" television, the screen goes on for about 1/2 second...
(More)
When I turn-on the power button to my 13" television, the screen goes on for about 1/2 second with no sound or picture (it's just black, but you can see the channel number in the upper right hand corner), then it automatically shuts off. What to do? Thanks so much for any assistance.
