Home | GE | Profile 26.6 cu. ft. Side-by-Side Ref... | My GE Profile Side By ...
GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Problem for GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with...
My GE Profile Side By Side Refig is freezing up
By mcdougald_ma on Nov 08, 2009
My GE Profile Side By Side Refig is freezing up in the bottom. I saw one solution regarding the drain plug, but how do I actually clear the drain? Sticking a close hanger down it? And where does the water go? I've never drained a pan (nor do I see one beneath my refig....
Model TFH30PRTA WW (1994)
Best Solution
posted on Nov 08, 2009
Helpful)
salde386
Rank: Guru
Rating: 93%, 41 votes
melt it out with hair dryer,slime builds up in the drain i use a steamer to clean out the drain line,if you have apiece of hose or something you can stick over or into the hole and blow it through or a compressor,you can try pouring hot water down the drain hole,sometime it's just ice in there or a plastic wire tie,i wouldn't stick anything metal down there alot of the lines are plastic, whatever you try to do to clear the drain just pour hot water down the hole and if it drains you'll know you cleared it hope this helps
Comments:
Nov 09, 2009
- you need something that can blow out that drain line,slime forms in there or sometime food like a piece of corn falls out of the bag and ends up in the drain,it's not always ice,i use a steamer,it usually takes like 5 seconds and the line is clear, it is a shark super steamer i use it to clean my harley,this thing is great look it up online,it's like 40 bucks
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks. I did pour hot tap water + baking soda into the hole, but didn't see anything happen. I've left the frig off for 7 days, still backs up. " - mcdougald_ma
Popular Solutions for GE Profile 26.6 cu. ft.
Questions and Unsolved Problems for GE Profile 26.6 cu. ft.
Do you recommend GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW?
Answer
Answer
no water to ice maker. I think water shute is frozen, because I can get water to the door. I have... (More)
Answer
Ice maker in our GE profile refrigerator is not making ice. The water dispenser works. The green... (More)
Answer
ge profile refrig pss265sgpa ssfg 409236 has a leak in the icemaker and now am having odor when I... (More)
Answer
GE Profile Refrigerator (PSS26MSWASS) The ice dispenser intermittently dispenses ice. Checked... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile 26.6 cu. ft....:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
