Question about Samsung (SP0411N) 40 GB Hard Drive
SAMSUNG IDE HDD SP0411N (40GB)
Sir,
My hdd is not detected as Samsung in bios instead it shows some wayward charcacters like Qsameng,etc. Secondly, if i boot it with as slave with a WinXP master disk, in disk management it doesn't initialize & gives a wrong size of app. 7GB.
Pls respond at sheroo16@rediffmail.com.
Thanking you in anticipation.
  • Sheroo Jan 07, 2008
    Dear Suisboy,
    After mailing u my query, yesterday I have already unpartioned and then re-partioned the drive with primary as-well-as logical drives with 'FDISK'. But as i re-boot, the partions are lost i.e. as if they were never made. Help ???
    Thanking 4 for immediate reponse and expect the same one again.
My hdd samsung sp0411n changes to sp14110!!!!!!!!, why is this happening ??sometimes its works properly sometimes not !! any solution ??
Posted on Dec 18, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Use the partion magic software may be ur disc remain unpartioned.
i recomend you to use fidsk or un partion all the disk and then re partioned may be it lost the boot sector allocation table.
Posted on Jan 06, 2008
    Brigadier General:
  • 6,966 Answers
Three possible reasons:
1. Your IDE cable is defective or is not seated/plug in correctly. Try to replace or re-seat/re-insert;
2. The on-board disk management of the hard disk is corrupted/defective. There is no remedy except to replace the PCboard or the entire hard disk;
3. Your motherboard BIOS/CMOS needs to be flashed and/or something is wrong with the IDE interface.
Of the 3, # 1 is the most common.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Slave drive
From a manufacturers website.
Aug 30, 2013 | Samsung Spinpoint Sp0411n 40gb Udma/133...
I have a 80gb samsung ata hdd which is clicking is ther any way to makr it work
it's possible but i would not recommend it due to failure and losing all your data...it's simply not worth it, replace it.
Jul 16, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Hard disk is not detecting samsung sp0411n internal hard disk is not detecting
Make sure the power cable and IDE cable is plugged in properly then boot your computer up again. If it does not work, test it on another computer to see if the hard drive works at all.
Sep 18, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Samsung SP0411N HDD (3.5" IDE 40GB) PC board replacement
The firmware is upgradable on these devices but only within the same Rev Series. Your best bet is to source a board with the same Rev and similar production date.
Assuming the board is all that failed this should r troubles. Try http://stores.shop.ebay.ca/Effective-Electronics__W0QQ_armrsZ1 as they carry a wide variety of boards. if they don't have it try a general search on eBay. Don't use anything more than the Samsung model # for the search though as most sellers haven't a clue about Rev#'s. Once you find a few similar ones you can ask the sellers for specifics.
If you can't find the proper board or if you do and it fails to garner results let me know and include your location(Country, State and City) and I will refer you into a clean room facility.
Chris
Oct 25, 2009 | Samsung (SP0411N) 40 GB Hard Drive
My sp0411n my hard disk of capacity 40gb it is showing 5gb space my know reason why it is showing 5 gb space
hi first off what OS (operating system) is installed. Did you install that OS?
If the answer is yes ,did you format and partition your hdd or did you format and create separate partitions and left atleast 30 gb unpartition
Feb 27, 2009 | Samsung (SP0411N) 40 GB Hard Drive
Sata hdd not detected in bios
Tried a differant SATA power inout into it? Is it making a clicking sound?
Feb 18, 2009 | Samsung SpinPoint T HD501LJ 500 GB SATA...
Harddisk
Check the jumper settings on the back of the drive, if this is the primary HD, set it to master, if secondary, set it to slave, if secondary still does not recognize, switch the ide cable so that the two drives are not on the same one.
Nov 19, 2007 | Computers & Internet
Hardisk cant be detected
hard disk can't detected by bios.i also can't format my laptop because of it can't detect my hard disk
Sep 21, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
My HDD has seen in BIOS but it can't read data
Maybe the pins on the inside are disconnected happened to my dads harddrive
Aug 20, 2007 | Samsung (SP0411N) 40 GB Hard Drive
CMOS auto detection of samsung SP0411N HDD stops and hangs
Hi download this program its seagates diagnostic tool, put in floppy disk and run program to make a boot disk, restart pc, and let it boot off the floppy disk and it will test the drive for you... http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD All the best john
Feb 16, 2007 | Samsung (SP0411N) 40 GB Hard Drive
Samsung (SP0411N) 40 GB Hard Drive Logo
405 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
