When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading C:windowssystem32jjpsmunsvhtdgzbq.dll The specified module could not be found.
Rundll.exe files are systems process directly related to your computer's Windows Registry
All Dll files are a part of vast library that contains code and data
that is shared by many programs. This helps to produce speed and memory
efficiency in your operating system by reusing the same code or file to
run many functions by various programs. An error occurs when program
aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
I can surf most sites but others including sign ons I losethe conection I run a diagnostic and it...
(More)
I can surf most sites but others including sign ons I losethe conection I run a diagnostic and it says I have port 80 ,443 and 21 faults
