Hi, the battery on my Tiny 755c10 is knackered so I just use mains power all the time. Before mine will start I have to removed the mains plug from the back, plug in straight back in and hit the start button and away it goes.
Does anybody know what series of drivers this Tiny uses B, Q, S, T, X, Y, or Z.
Hello there: First i would check the power cord to ensure that it is in good working order and check the connection area to see if the conection on the laptop is loose if so there may be a part that is broke in their. Next i would check to see if the battery is getting charged remove the battery and check the places where the battery connect to to see if they are loose or need cleaning rubbing alcohol works well on this just make sure that it is dry before you try to restart the computer ok? also you can remove the battery and leave the power cord plugged in and see if this will let you get the laptop started if still nothing you may want to consider taking the computer to a repair shop and have them test the power switch to see if it is working or not or see if the motherboard is not working . One other thing that you can is to find the reset button on the back and use a small object like a toothpick or a paperclip and press in on it and hold it it while pressing the power button, this can sometimes get them going ok? I hope that his has s been very helpful for you Best regards michael
I am looking for a TRUE desktop-replacement.
I am looking for a quad-core min 4. GB of DDR3...
(More)
I am looking for a quad-core min 4. GB of DDR3 RAM.
I also want a better GPU then just the intregrated one so that I can truely play games hi-res, just search me the best laptop you can find, but not from dell, that includes Alienware.
Thanks in advance
When typing an email in outlook at times it will delete the entire text I have typed for no apparent...
(More)
When typing an email in outlook at times it will delete the entire text I have typed for no apparent reason?
