Missing sir sudden my system was restart then one partition missing . chek my system cables overall checked my system importent date is in. using matrox card
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Well check ur hardrive in slave to an other system and then see if it show the missing partion then copy the data and format it.
if it wont then use partion software to check it like partion magic.
may be your system changed the partion to RAW format i mean UNPARTITIONED space due to improper shutdown.
Posted on Jan 06, 2008
What is DigBus?
IN Matrox Digi suit card its a non linear vedio editing card which has a small ribbon cable which is connected as a bridge between two cards is called digits cable.
May 07, 2014 | Matrox DIG-BUS/MBDK Graphic Card
BOOTMGR is missing,
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Check your optical drives, USB Ports, and floppy drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable disc, external drive, or floppy disk.
  3. Reseat all internal data and power cables. BOOTMGR error messages could be caused by unplugged, loose, or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  4. Perform a Startup Repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR.
    Even though a Startup Repair is a common solution for BOOTMGR problems, don't worry if it doesn't fix your problem. Just continue troubleshooting - something will work.
  5. Write a new partition boot sector to the Windows system partition to correct any possible corruption, configuration problem, or other damage.
    The partition boot sector is an important piece in the boot process so if there's any issue with it, you'll see problems like "BOOTMGR is Missing" errors.
  6. Rebuild the Boot Configuration Data (BCD). Similar to the partition boot sector, a corrupted or incorrectly configured BCD could cause BOOTMGR error messages.
    Important: The following troubleshooting steps are much less likely to help fix your BOOTMGR problem. If you've skipped any of the above ideas then you may have overlooked a very likely solution to this problem!
  7. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  8. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, please understand that you will lose them all if you continue with a clean installation of Windows!
  9. Replace the hard drive and then install a new copy of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
SysFlashwww.sysflash.com
May 29, 2013 | Lenovo IdeaPad S10-3t 0651 Notebook
Videos play slow and not rruning smoothly on matrox mga 200
First of the card is out dated so there is not too much support for it.Do you update your card driver.If not look at Matrox Support Drivers.
Did the problem is recently? What is your OS?
New video formats demanding a lot of resources from the devices that are not updated.So consider buy a new one with higher performance.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | Matrox MGA G200, PCI Video Card
The computer turns on but there is nothing coming on the screen, its not the video card because i just bought a new one to put in
Hi..
Besure that the video card you inserted are correctly inserted you need to check it first. You need also to installed the vieo card driver. If the sam things occurs you need to disassemble the unit . Try to remove the proccessor and clean it after that insert it again. Check all the power cord and cable wire if it is correctly install in their respective port.
Thanks for using fixya..
Regards
ICmanServer
Aug 05, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
NTLDR is Missing Press Ctrl+Alt+Del to Restart Problem! No CD No Floppy to reboot! How to fix it?
its necessary to you a bootable cd or floppy system disk. ntldr is part of the hard disk partition data, it this partition if missing then you cannot open your system until you use bootable operating system.
Jul 15, 2009 | Compaq Evo D500 PC Desktop
Matrox G550 TV out wont work with Vista drivers
how about the DVI-to-HD15 cable? did u connect it?
or did you try to re install the operating system?
Apr 05, 2009 | Matrox G450, G550, P750 TV-Out Cable:...
Matrox rt.x 100 / adobe premier 1.5
There are Thousands of Problems associated with Vista right Now. I just got word this week that a New Windows Version is Coming out to Replace Vista Because of all of the Problems Everyone is having with Vista. Keep the Stuff you have right Now as It very well may be Compatible with the New Version Coming out Very Soon.
Jan 24, 2009 | Matrox RT.X 100 (RT.X100) Video Capture
Matrox millenium G450 Driver
sir.......!!!! I nend G45fmdvp32db driver
Sep 25, 2008 | Matrox G450 Millenium 32MB DDR PCI Dual...
Problem with booting my device
seems your file system was corrupted. try to boot your laptop through cd..installation would show the partition details. here just check all partition are in gud file system. if it shows like "unknown" u need to format the partition. if u have any important data in that partition just connect that hdd as a secondary disk and try to copy the data's
Jul 24, 2008 | Microsoft Computers & Internet
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
