Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Urgent: Communication Error- Camera Not Detected
Ok. why can't I transfer images to my PC. I didn't read the manual 1st (sorry; usu. most softwares are self-guided). I think my camera connected to my PC w/ the usb cable while I was installing the software. I've read that was a big no-no; hence my current camera problem. I have un- and re-installed the software w/o the camera attached to the PC. What can I possibly do now that doesn't involve returning the camera? Please help!
  • 5 more comments
  • Anonymous Jan 08, 2008
    exact same problem here
    sorry I'm no help
  • bhedge Jan 10, 2008
    same problem
  • incompetent Feb 13, 2008
    Me too. Pls help!
  • Anonymous May 09, 2008
    same thing. communication error and wont connect. however mine has worked fine for months and months, but now this.
  • Anonymous Sep 10, 2008
    Same problem, had camera connected while installing I think.
  • Anonymous Sep 18, 2008
    I have had my camera for about two years now... and back in May, I started to get the "Communication Error" which was weird because I've taken literally thousands of pics and loaded them to the computer from the camera. I tried switch to a new cable... it didn't work. Then back in July I started to get a message saying that none of the pics match the download criteria, meaning that there weren't any new pics. Come to find out that meant that I had more than a thousand new pics to download, so i deleted some and then it worked! but since then I get the Communication error too... but I only have maybe 200 new pics to download. I tried deleting some, and re-installing the software, didn't work.... AAHhhh!
  • Anonymous Apr 12, 2009
    same problem here too
I have the same problem but I just changed the SD Card inside with another SD Card (non SD HC) and the communication problem went away.
Posted on Oct 11, 2009
Error message: communication error
I use a USB cable and never see a communication error
Jul 08, 2015 | Canon PowerShot SX520 HS Digital Camera...
How to fix the error code for Ricoh 1232c sc517 and how to clear it
there's no error code like that
http://www.unitedtechsonline.citymax.com/page/page/4653767.htm
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER)
384-385:IMAGE DATA TRANSFER PROBLEM WHEN TANDEM IS USED(SBU,INTERFACE
BOARD,SICU,PRINT CONTROLLER)
390:TANDEM IMAGE DATA TRANSFER ERROR(NOISE,SICU,INTERFACE BOARD)
391-392:IMAGE STORAGE ADDRESS ERROR(SICU391-01)
395:CD-R/RW ERROR, INTERFACE BOARD ISSUES
397:CD ACCESS ERROR
398:CD-R/RW DATA ERROR
400:TRANSFER BIAS ROLLER ISSUES
401:TRANSFER ROLLER
430:QUENCHING LAMP ERROR
440:DRUM MOTOR LOCKED
441:DEVELOPER MOTOT LOCKED
491:LASER COOLING FAN LOCKED
495:TONER BOTTLE PROBLEM
496:TONER COLLECTOR BOTTLE PROBLEM
501:LIFT PROBLEMS FOR TRAY 1
502:LIFT PROBLEMS FOR TRAY 2
503:LIFT PROBLEMS FOR TRAY 3
504:LCT 1ST TRAY PICKUP OR LIFT PROBLEM
505:LCT 2ND TRAY PICKUP OR LIFT PROBLEM
506:LCT 3RD TRAY PICKUP OR LIFT PROBLEM
510:PAPER FEED MOTOR PROBLEMS
511:LCT MOTOR PROBLEM
515:TANDEM REAR FENCE MOTOR PROBLEM
520-521:DUPLEX JUGGER MOTOR PROBLEMS
531:FUSING DUPLEX MOTOR LOCKED
532:RELAY MOTOR LOCK
541:OPEN FUSER THERMISTOR
542:LOW FUSER TEMPERATURE
543:HIGH FUSER TEMPERATURE
544:HIGH FUSER TEMPERATURE
545:HIGH FUSER TEMPERATURE
546:LOW FUSER TEMPERATURE
547:ZERO CROSS PROBLEM
550:WEB EXPIRED
591:TONER SUPPLY MOTOR PROBLEMS
592:TONER BANK MOTOR PROBLEMS
601:SBICU TO SBU COMMUNICATION PROBLEMS
602:SBICU TO HARD DISK DRIVE BOARD COMMUNICATION PROBLEMS
620-622:SBICU TO ADF COMMUNICATION PROBLEMS
625-626:BCU TO FINISHER COMMUNICATION PROBLEMS
630:LINE ADOPTER TO CSS CENTER COMMUNICATION PROBLEMS
640-645:BCH TO SICU COMMUNICATION PROBLEMS
646:SICU PROBLEM
650-653:COUNTER ERROR JAPAN
701:ADF P/U ROLLER PROBLEMS
702:ADF FEED MOTOR PROBLEM
703:ADF TRANSPORT BELT MOTOR PROBLEM
704:ADF EXIT MOTOR PROBLEM
705:ADF ORIGINAL TABLE LIFT ISSUES
720:FINISHER LOWER TRANSPORT MOTOR ISSUES
722:FINISHER JOGGER MOTOR ISSUES
724:FINISHER STAPLER HAMMER PROBLEMS
725:FINISHER STACK EXIT MOTOR PROBLEMS
726:FINISHER SHIFT MOTOR PROBLEMS
727:FINISHER STAPLER ROTATION PROBLEMS
729:FINISHER PUNCH MOTOR PROBLEMS
730:FINISHER STAPLER MOTOR PROBLEMS
735:FINISHER PAPER STACK PLATE MOTOR PROBLEMS
736:FINISHER EXIT GUIDE MOTOR PROBLEMS
737:FINISHER FULL STAPLER HOPPER
738:FINISHER SHIFT TRAY LIFT MOTOR PROBLEMS
739:FINISHER FOLDER PLATE MOTOR ERROR
740:FINISHER FRONT SADDLE STITCH STAPLER MOTOR PROBLEMS
741:FINISHER REAR SADDLE STITCH STAPLER MOTOR PROBLEMS
742:FINISHER JOGGER SIDE FENCE MOTOR
750:COVER INTERPOSER BOTTOM PLATE MOTOR PROBLEMS
800:VIDEO OUT TRANSFER,CONTROLLER BOARD
804:VIDEO OUT TRANSFER,CONTROLLER BOARD
818:OPTIONAL BOARD,CONTROLLER BOARD, SYSTEM PROGRAM
819:BAD SOFTWARE
820:CONTROLLER BOARD OR SOFTWARE
821:CONTROLLER BOARD
822:HDD PROBLEM
823:NIB, CONTROLLER BOARD
824:CONTROLLER BOARD, NVRAM
825:NVRAM ERROR
826:NVRAM
827:CONTROLLER BOARD, RAM
828:SOFTWARE,ROM,CONTROLLER
829:RAM, CONTROLLER
835:CONTROLLER,CENTRONIC LOOPBACK CONNECTOR
836-837:FONT DEVICE
838:CONTROLLER BOARD
850:IP ADDRESS,CONTROLLER BOARD,NIB
851:1394 I/F CONNECTIONB,I/F INTERFACE,CONTROLLER BOARD
860-861:HDD
862:HDD BAD SECTORS
863:HDD
864:DATA TRANSFER ISSUES
865:HDD
900:NVRAM PROBLEM.ELECTRICAL COPY COUNTER
901:MECHANICAL COUNTER ISSUES
921:IMB, BICU FAILING
922:IMB, BICU FAILING
924:DRAM,BICU,IMB FAILING
925:BICU, IMB FAILING
926:BICU, IMB FAILING
951:F-GATE SIGNAL ERROR PROBLEMS
953:SCANNER IMAGE SETTING ERROR ISSUES
954:PRINTER IMAGE SETTING ERROR ISSUES
955:MEMORY SETTING ERROR ISSUES
964:PRINTER READY ERROR ISSUES
966:POLYGON MOTOR PROBLEM
970:SCANNER READY ERROR
980:HDD ACCESS ERROR
981:BICU, NVRAM
982:HDD CONSTRUCTION ERROR
984-987:HDD DATA TRANSFER ERROR
990:SOFTWARE PERFORMANCE ERROR
991:REBOOT SOFTWARE ERROR
997-998:DIMM, RAM ERROR
999:PROGRAM DOWNLOAD ERRORS
Oct 29, 2008 | Ricoh Office Equipment & Supplies
Camera says "communication error" when trying to transfer images to computer. Why?
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Jan 10, 2012 | Canon G12 Digital Camera
Impossible to connect camera with PC. no driver in the PC for camera powershot A510. What's the matter?
Just figured this one out. Man, they don't make it easy. I'm borrowing my roommate's PowerShot A510 and since it has a USB port going out, I'd assume I could simply connect the camera to my PC and access my images directly. Almost every other camera I've seen will register itself to Windows as a straight USB connection (prompting the Windows screen asking how you want to open the connection - 'open folder' etc). This one just sits dead quiet about things :)
If you've just bought this camera at a garage sale or are borrowing it or for whatever other reason do not have the "bundled" software and driver CD or have the camera's serial number, do not bother trying to find windows drivers or try to obtain any software from Canon. You won't get very far.
FINALLY found the solution in the User's Manual (which was free thank God). You can download the manual here: http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510#BrochuresAndManuals
(Select your operating system and download the "PowerShot A520/A510 Camera User Guide". File name is PSA520510CUG-EN.pdf)
In the User Guide, page 107 (I'll paraphrase):
1. Put camera in Play mode (the switch on the back (green arrow in green box)
2. Press Menu button (center one of the three along the bottom of the view screen)
3. In the 1st menu option (Play Menu, again green arrow in box highlighted), use the wheel button to scroll down to highlight "Transfer Order". Press Set (center of wheel).
4. You should now see "Transfer Order (DPOF) at the top of the screen and "Qty. of images 0".
5. Below "Qty of images 0" you'll see "Order", "Mark All", and "Reset". Order lets you select individual images; Mark All marks all current images for transfer; and Reset is reset. Press Set to choose.
Note: pressing the Menu button while selecting images brings you back to this main screen. If you are already at this main screen and you aren't ready to do your transfer yet, DON'T press the Menu button from this screen as it will initiate the transfer to your computer. Not a horrible thing, but might cause a mini freak-out.
7. Once you're selected the images you want to transfer, from the main Transfer Order window (now showing "Qty. of images" with a count of the images you selected), press the Menu button.
8. You'll see a white progress bar at the bottom of the screen. Don't worry! it's not deleting files or something bad.. (my first thoughts :) ..
9. Go to your PC and Voila! the Windows AutoPlay screen is now active!
10. Proceed with normal Windows USB operations (transferring at least, I didn't try any deletion).
I hope this helps somebody else out there who spent the last 3 hours trying to dig through internet hell to get this to work.
Atm, this is as much as I know so I probably don't have any good answers for any questions. Sorry :))
But, hope this helped at least!
Mar 12, 2010 | Canon PowerShot A510 Digital Camera
Computer cannot detect camera, tried different USB cables
is the usb port active still? try wiggling the cable at the camera connection.good luck farr64
Apr 30, 2009 | Cameras
Camera not recognized by PC
Hi
Your best bet would be to go out and buy a card reader. This solves your problem and save you in other ways. First of all the whole downloading process is a lot quicker. Second your save wear and tear on your battery. Three no need to plug in the power cord if you don't want to run on battery power. lowers the risk of damage to your camera and possible accidents by the cable getting pulled and taking your camera with it.
Card reader are really cheap.
Regards
Jul 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon zoombrowser Ex downloading problem
Try updating the Zoombrowser software.
If you have a connection to the camera, go into my computer and get images directly off the camera using scanner and camera wizard, microsoft's default program. This will at least allow you to transfer your images until you can resolve the software problem.
If you have no connection to the camera via your computer, you need to try some other troubleshooting steps to get a connection. I will post those below in the next post.
May 30, 2008 | Canon PowerShot G7 Digital Camera
Software for camera not suitable for windows2007
Have a Nikon Coolpix 1L. Have installed software. Pictures
won't transfer. USB OK. For Windows Me Mass storage chosen.
Display says Communication error.
Nov 13, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
JVC gr-d270 driver
Hi guys,
I have a JVC gr-d270. the CD came along with it is useless. my computer cannot detect the video cam hrough USB. I have to transfer my videos to my computer. Can anybody help me with the driver atleast. Im using windowsXP sp 2.
Thanks
Jun 04, 2007 | JVC GR-D270 Mini DV Digital Camcorder
I am still getting communication errors. Is my camera defective? (Fuji DS, DX and MX digital cameras only)
As long as the camera is taking pictures and playing back the pictures on its LCD, most of time the camera is OK. Serial communication port of Digital Camera is rarely damaged. If you are using Windows '95, there is a way of verifying the serial communication port. Following are the instructions: a. Open Control Panel from the Start/Settings menu. Double-click Accessibility options, then go to Mouse and activate mouse keys. This feature enables you to use the numeric keypad to move the mouse pointer. (For details please refer to the Help index of Windows 95) b. Turn off the PC and the Digital camera. Remove the Serial mouse from 9 pin connector, then connect Data transfer cable to the 9 pin connector and the other end of cable connect to the Digital camera. Turn ON the PC and the Digital camera. From this point the numeric keypad can be used for Mouse functions. Start the FUJI data transfer software, select COM 1 from the Communication ports within the "Communications Settings" item of the "Camera" Menu. c. Go to "Get images from Camera" of the "Camera" Menu. If you get a blank thumbnail, your Digital camera is communicating to the PC. To receive thumbnails of all pictures go to "Edit", go to "Select All", then click the 3rd Icon from the left. Progressive indicator shows "Receiving thumbnails". In this case the Camera is OK, and the problem is other than with the Digital camera.
Aug 30, 2005 | Fuji DX-7 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
394 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
