Home | Keurig | B60 Coffee Maker | It will not brew
Keurig B60 Coffee Maker
Problem for Keurig B60 Coffee Maker
It will not brew
By rbbertvasque on Nov 08, 2009
it will not brew
Solution #1
posted on Nov 09, 2009
Not Rated)
melba846
Rank: Wiz  Kitchen Appliances  Expert
Rating: 78%, 12 votes
Try descaling the reservoir using citric acid or a produce call Dezcale; or the air pump is bad. Can you give me more information...does it try to brew? Does the unit cup size come on?
Was this helpful?
Yes
No
Popular Solutions for Keurig B60 Coffee Maker
Questions and Unsolved Problems for Keurig B60 Coffee Maker
Do you recommend Keurig B60 Coffee Maker?
Answer
Answer
It will not brew at the programmed time.
Answer
It starts to brew, then only dispenses a little amount of coffee. I have checked the exit needle and... (More)
Answer
I use 2 Keurig B40's for my display and I need to replace my broken water compartments... please... (More)
Answer
1 yr old b60 model all of a sudden will not brew after it has drawn extra water from the resevoir... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Keurig B60 Coffee Maker:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
