Question about Quasar VV-2002 20 in. TV/VCR Combo
High pitched sound
Hello, i have a quasar 29" standard tv and it's making this really annoying high-pitched whistling sound, and if you slightly scoot the tv or tap the side of it, the noise will temporarily stop. How or can I fix this?
  • 78 Answers
You can fix this if you are very careful. it is call a high voltage leak. inside of the tv, close to where the power comes in will be what is called a high voltage transformer. if you are electrically inclined, unplug the tv, take the back off and then hook the power line up and turn the tv on. with the lights off in the room and a flashlight handy, look at where the sound is coming from. locate where the sound is coming from and look very carefully(very carefull not to touch with your hands or head to any part) for a white-ish blue arc of electricity. if you can see this then that is where the problem is. to fix it you will need to put something in between the two places that it is arcing from. a piece of plastic or silicon putty or anything non-conductive will work. again, be very careful or you might get the dogsnot shocked out you.
Posted on May 03, 2008
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
Sounds like air is shooting out when accelerating. Could this be an exhaust leak? Plugs, coils, hoses seem fine. Noise is coming from passenger side under engine sounds like.
yes could very well be an exhaust leak.but that should be kinda loud and annoying..also u could have a slight whistling sound coming from ur air intake hose coming from air cleaner box to ur intake or throttle body or ur air inlet goin to the motor. when the motor is accelerated it would produce a high pitch sound like a whistling .hope this can help
Jun 28, 2015 | 2001 Mazda Tribute
When i turn on the tv, it makes a high pitched sound every couple seconds coming from the back of the tv, (not the speakers) and the screen is black.
hi there !
what You'd just heard was the flyback singing or the High frequency whistle at the high voltage section of your tv set it is located inside, Replacement of defective component will do solve your problem, thank you
Dec 25, 2010 | RCA 20F512T 20" TV
No pix/sound, just high pitched whistle
Ur tv the high voltage it dead,the FBT,the flyback transformer.The big black block of plastic with a red wire with a black cap that hook up to the CRT(tv tube) is dead.The FBT,flyback transformer needed it to be replaced to solved this problems.Call the shops,take estimates for the best deal to do the repair.This is one of the main part of the tv to put HV in CRT(tube tv).It pretty hard to find this FBT these day,because of the discontinue of making of Amalog tvs.
Jun 06, 2010 | RCA 35V432T 35" TV
Tv suddenly died, black screen with high pitched whistle
Ur high voltage is dead,it the FBT,the flyback transformer,the big black block of plastic with a red wire with a cap go to the CRT(tv tube).It have a paper
clip like '5 steel to the block high voltage go throught
that where the high pitch came from.
Sep 30, 2009 | Televison & Video
Super high pitch whistle from tv, only powering it off helps.
Shut it off and unplug. You have a serious HIGH VOLTAGE problem that could cause a fire. Professional repair needed.
Mar 07, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Television won't power up
It sounds like the high voltage circuit got damp and arced. This arc caused the horizontal output transistor to short.
You might try replacing the output transistor if you're experienced in this type of repair. If not then you need to take it to a repair shop.
The "whistle " you're hearing is the power supply indicating that it has a short on its load. When the power supply has an over load (short) its frequency drops down when your ear can hear it oscillating. This type of power supply is a switching power supply normally operating a several thousand hz(cycles) which is out of range of human hearing.
Stargazer
Mar 15, 2008 | Televison & Video
An Annoying High Pitch Sound
Can be either noisey yoke or noisey flyback transformer........T.
Dec 12, 2007 | RCA F32450 32" TV
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
Quasar VV-2002 20 in. TV/VCR Combo Logo
109 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
