I have a Poulan 2375 chainsaw. The fuel lines became brittle and broke. I purchased new lines, but I need a diagram to see where the belong... there are two different size lines... but where the heck do they go? (yes, I pulled the carb off) Any advice?
The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH Lou
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Poulan Wild Thing 2375 18" Gas
I have two Stihl 010 chainsaws. One will only idle and the other will run strong for about 10...
(More)
I have two Stihl 010 chainsaws. One will only idle and the other will run strong for about 10 seconds and then die off. It appears that both are carburetor related, but do you have a Walbro carburetor diagram. thanks, Richard Cook
I have a Speare & Jackson petrol chain saw purchased from argos. The chain oil feed...
(More)
I have a Speare & Jackson petrol chain saw purchased from argos. The chain oil feed mechanism has stopped working. Is there a workshop manual available so I can attempt a repair?
I have the same problem as gaffierok except it's a drive sprocket for an electric mastercraft...
(More)
I have the same problem as gaffierok except it's a drive sprocket for an electric mastercraft chainsaw MC 3000 from Canadian Tire (54-5713-6)
