The equipment does not work at all. There are lights on the panel when it is plug into the outlet. Sometimes the compressor runs but no water accumulates in the tank. i would appreciate any suggestions to solve the problem. Thank you
I have a kenmore(580.54701) 70 pint it comes on momentarily shuts off and displays 01 while full...
(More)
I have a kenmore(580.54701) 70 pint it comes on momentarily shuts off and displays 01 while full indicator flashes slowly. checked coil unit it was iced up. I let it thaw . The blower was working fine and filter looked clean. After it thawed out I inspected the coils and they were clean. I restarted it. It ran for a while the the code came back. This time there was NO ice buildup. I use a hose for drainage and I know it's not pluggrd up Can anyone tell me what that code means.Thanks!
Kenmore 54351: The water collects inside the machine, but doesn't feed properly into the water bin,...
(More)
Kenmore 54351: The water collects inside the machine, but doesn't feed properly into the water bin, so spills out from the rear onto floor. Help!
fan does not run. can replacement fan motors be purchased? appliance is less trhan 2 years old. when...
(More)
fan does not run. can replacement fan motors be purchased? appliance is less trhan 2 years old. when on, the compressor gets hot, does not dehumidify and fan motor does not run.If fan motor is available, where may one be purchased and at what price?
is there a circuit breaker built in on this unit? It starts up then turns off as soon as the...
(More)
is there a circuit breaker built in on this unit? It starts up then turns off as soon as the compressor comes on
