Question about Emerson EWD7004 DVD Player
Installing or connecting my dvd player to my television
I have received a used dvd player from a friend and i am confused on where to connect all the plugs to all the different colours. I do not have the instructions Can you help me?
I do not have instructions to install my dvd player
  • 689 Answers
Here is the manual which contains easy steps to install the DVD player.
Good Luck
Posted on Jan 06, 2008
Trouble connecting my insignia 32in.Tv To my DVD player
Yes you can use Just the red,white and yellow cable from your dvd player to the make sure you have it connected correctly...sometimes its easy to confused the yellow and white connections. make sure your tv is turned to Input that you have used for connecting the cables on the back....such as...input input 1 on your tv....or if it says dvd...then select dvdv on yoru tv..You can use a HDMI cable...just plug HDMI from your dvd player to your tv and select HDMI on yoru tv..Good luck
Mar 08, 2015 | Insignia IS-LCDTV32 32 in. Television
Confusion connecting my receiver to the RCA255 dvd receiver for cd use
Ok is your cash converters purchase a RCA, RTD255 system or is the RCA255 you quote something else, I'll assume that we are dealing with the first, and that seems to be a All in one system that contains speaks amp etc
You also have your new AVR 310 which is amplifier that one would connect a stand alone DVD/CD player to, You wouldn't connect the cash converter purchase to it, it is a seperate system.
You could use your cash converter system alone without the AVR310 but not with it.
Nov 18, 2007 | RCA RTD255 System
My dvd player is hooked up to the samsung receiver. I am using two remotes, one is the cable box remote where I hit tv and power and then cable and power and then the red power button on the samsung remote...
What you have to do is select the proper item on the receiver since that is what you have the dvd player connected to. Pressing bd/dvd on the receiver is not necessarily the right thing to do. All receivers have an input or source or function button that will enable you to choose the correct area where your device is connected. The way you have this hooked up may not be right but first things first. You will need to have a movie playing in the DVD player so that you see the numbers advancing. Go to each input/source/function on the receiver until you hear the DVD. Ok great! Now getting the picture is a little more tricky so please follow along carefully.
The cables going from the DVD player to the receiver: The cables should be connected to where it says OUT on the DVD player or hdmi out from the DVD player to one of the receivers INputs. Once that proper connection has been confirmed make sure the receiver is connected to the television for both video and audio. You must have a video cable as well as audio cables between the television and the receiver or an hdmi cable. If it is not connected to the television in this way that is the problem right there. In fact you probably have a cable going from the television's audio OUT going INto the receiver. In order to see your DVD player you will also need to connect the receiver's video OUT to the television's video IN.
You will need the television's remote to be able to change the source/input/video/aux on the television. You might be able to change it with the cable box remote by pressing tv and then input/source/video.
ALTERNATELY: You can connect the DVD player's Video OUT directly into the television's INput. The DVD player's Audio OUT cables would be connected directly to the receiver's IN.
Either way you will have to choose the correct input on the receiver as well as on the television itself.
May 16, 2011 | Samsung HW-C700
Connecting a DVD player to your stereo receiver (or television, if you don't have a receiver) involves making two basic connections: audio and video.
The first connection to make is for the audio portion of the signal. There will be several options depending on the receiver you have.
  • The best choice (if available) is either to use an optical (also called Tos-link) or coaxial (RCA) digital connection. These two choices are equal in quality. In order to use either of these, you will need to have both an output on the DVD player, and an input on the receiver. Only receivers with built-in Dolby Digital decoders will have this type of input.
    The audio outputs on a DVD player
  • If your receiver does not have a built-in Dolby Digital or DTS decoder, but is "Dolby Digital ready," look for the 5.1-channel Dolby or 5.1-channel DTS. This connection involves six cables, corresponding to different speaker channels: left front, center front, right front, left rear, right rear and subwoofer.
  • The last option to connect the two components is with analog RCA outputs. This is a two-cable connection, with one cable delivering the left speaker sound, and the other cable delivering the right. This connection will deliver only stereo sound, but it may be your only option if you are hooking up directly to a television, or if you have an old receiver with only two channels.
Now let's take a look at the video connection.
  • The best quality choice is to use component connection. This connection consists of three cables: color-labeled red, blue and green. The quality is superb. However, these connections only exist on extremely high-end receivers and television sets.
    The video outputs on a DVD player
  • The next option is s-video. One cable connects the DVD player to the receiver in this setup.
  • The last option, similar to the audio setup, is to use the analog RCA video output, usually color-labeled yellow on both ends. This will deliver the lowest quality, but will suffice for most older, analog televisions.
Jul 03, 2010 | Symphonic Televison & Video
Manual too confusing
The easiest way to think of your equipment is that in it's name is it's function; it "receives" signals. Then sends them out through the speakers. There are only a few exceptions in that there may additional outputs depending on the design...they may be for video or external amplifiers.
All of your components you would like to connect to the receiver will have output connections. Power off all components. Connect those to the labeled input on the receiver. If a component that you are connecting has both audio AND video such as a DVD player or TV, both connections must be made to the same input section to be able to use them simultaneously.
Apr 02, 2010 | Audio Players & Recorders
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
How to hook up protron pds-2315
First of all, the PDS-2315 is not a DVR (this question is incorrectly categorized), it is a home theater system. Also, this system is not a receiver -- it is a DVD player (DVD/CD/HDCD/CD-R/CD-RW/Kodak PCD Playback) with a "full function" Karaoke feature with two microphone inputs. If you haven't figured out how to set it up in the past 11 months, this is how you do it.
1. Connect the supplied RCA cables (labled FR, FL, SR, SL, Cen, and SW) to the corresponding RCA connections in the back of the DVD player and the back of the Sub-Woofer.
2. Connect the DVD Player to your television.
A. Video:
There are several options here depending on your available Television inputs: Coax Cable, Component (yellow jack), S-Video and Composite (composite providing the best video resolution and coax the poorest). HDMI is not available. Use s-video or composite if you can. You will note that the composite RCA jacks are colored Orange, Blue, and Green. In a pinch, any RCA Cables will work - just don't cross the color codes between the DVD Player and the television. If you need to use coax you will need a coax to RCA adapter. If your television only has a component jack (yellow), it's a simple connection between the two.
B. Audio:
On the back of the DVD player you'll find two RCA jacks labled "Main R" and "Main L". These will be connected to your Audio Out connections on the back of your television. If you don't have Audio Out RCA jacks on the back of your television, but have an earphone jack, you can purchase an RCA adaptor to make that connection. With rear audio out jacks, you should have an option in your television's audio setup menu to select those outputs. (DO NOT CONFUSE "AUDIO OUT" WITH "AUDIO INPUT" because the will look identical.) If you don't have either of these connections, you will not be able to use the system to listen to television signals.
3. Connect the speakers. Each of the speakers is labled with their position (FR, FL, CEN, SR, SL). The speaker wires are color coded to the spring connectors in the rear of the sub-woofer/amplifier. Press the spring lever and place the wire into the opening. For proper biasing, place the color coded wire into the colored spring connector and the other wire into the black connector for the specified speaker. Connecting the speakers should be very easy. If the ends of the speaker wires become damaged, simply strip the wires back half an inch and connect as above. Place the speakers as specified by their position lables (FL, CEN, FR in front of the television and SL and SR to the right and left of the seating.)
4. Plug it in and power on. You'll need to plug in both the DVD player and the sub-woofer. Press the power button, hit the open/close button on either the DVD player or the remote control and put a disc in the machine. If you don't have a picture or a "Protron" title screen, hit the "P-SCAN" button on the remote (top left corner below the "STANDBY" button).
5. Hit the "SETUP" key and enter your system's information and you're done. Your system will work just like any other DVD player with theatre quality sound. --With the added feature of functioning as a Karaoke machine! Just add proper Karaoke CDs, a couple microphones, a bunch of friends and copius amounts of alcohol . . .
Feb 21, 2009 | Protron PD-DVR100 DVD Recorder
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
Can't get picture after connecting to receiver nad speakers
Sounds like something got confused in the re-wiring...if the TV signal from cable doesn't involve a box, then the co-ax should go straight to the "cable in" or "RF in" on the TV, and the sound equipment gets connected to output ports on the TV. Otherwise, try bypassing the video connections on receiver or whatever and go directly to TV...My surround sound has video in and out, but I've never used them, it doesn't matter.
Feb 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
if you're using a simple connection, connect the yellow colored output connection of your DVD to the video input of your TV. The audio out of the DVD red and white will go to the red/white of the TV also. If your TV is one channel or monaural, then you can only connect either the red or white.
you can also makje the connections in stereo if you are using a DSP amplifier. in that case your DSP should also have a video input and that is where you will connect your DVD. The video output of your DSP will go to the TV input. Just remember the color, Yellow is video signal )composite) and Red/White for left and right chanel audio.
Jan 05, 2008 | Aspire Digital AD-900 DVD Player
Emerson EWD7004 DVD Player Logo
124 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
