Question about Lexmark JetPrinter Z25 InkJet Color Printer
Lexmark printer my printer keeps telling me to load paper before printing and the paper get stuck before printing begins
  • Anonymous Mar 26, 2014
    can not print or copy the paper keep getting stuck
I do not have my CD to install printer Lexmark Z25
Posted on Feb 12, 2008
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
My lexmark t430 says load mp feeder letter. what does this mean?
You have send a print job from your application (ex. word), and the paper format in this appl. is letter. The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (upper the tray).
If you press the GO key the print probably proceeds with print job (if has the paper load in mp feeder)
Feb 23, 2011 | Lexmark T430 Laser Printer
My lexmark all in one printer x5470 keeps jamming the paper and it wont print?or the paper will go in partially and print but nothing will happen then it will tell me to reload the paper and press the...
Most probably a mechanism problem. Try to remove all sheets of paper. Take out the cartridges from the printer. Close the cover. Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. Check for any obstructions or foreign objects in the feeder. Wait at least 30 seconds before plugging the power supply back in the printer. Once printer is ready, reload the cartridges. Load about 10-15 sheets, don't load too much. Let it print the alignment page. If this doesn't help, then most probably it's a hardware issue. If this is the case, I strongly suggest you contact Lexmark Technical Support to further investigate the problem.
Jun 11, 2010 | Lexmark X5470 All-In-One InkJet Printer
Loaded paper not going through
Annie, did you try to feed it one paper at a time? in many printers the feeder doesn't do a good job separating one paper from the rest.
another thing you can do is to turn off the printer and back on. this might get it out of the stuck status it is in.
did you check there isn't any paper stuck in the feeder?
Mar 10, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x7550 printer jam. I cleared the jam and hit the check mark button as directed, but it keeps looping through the paper jam sequence. It does not seem to register that the jam has cleared. If I...
There will be some form of error clear code that would need to be entered. It would be something like "holding down the print key and powering on the printer at the same time" The manual may tell you.
There are different combos for different manufacturers.
Nov 17, 2009 | Lexmark X7550 InkJet Printer
Paper goes in slanted and wont print
Take the paper out off the printer and make sure there is no debris inside of the area where the paper normal loads from. If there is something stuck, you would have to shake the printer a bit to maybe get it loose to get the debris to come out.
Keep in mind sometimes kids put things in there and it gets in the way of the paper path. Also make sure there is no paper stuck in the paper path at all as this can cause the paper to go in slanted.
Aug 16, 2009 | Lexmark X2500 All-In-One Printer
When i try to print on my lexmark x3650 it wont take in the paper and then it tells me that its out of paper when the paper is in it.
hi
there is a small spoke like thing on the paper loading area check to see if this is stuck or brocken or the connection to the sensor there is brocken
cheers
pls rate if this was any help
Jul 13, 2009 | Lexmark X3650 Printer
Paper stuck while printing on lexmark X5470
You might have a little paper stuck inside your printer or just clean the pick-up roller with alcool and try it again.
Mar 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
Printer problem
Samsung 4100 laser printer, scanner, copier
The paper gets stuck in the roller and is not drawn up to the drum. The beginning of the problem started when the paper was never pulled from the drawer. When I open the paper drawer after a Paper Jam error, the paper is bent backward but still detached. Now it is drawn in but sticks.....margoa
Oct 16, 2007 | Office Equipment & Supplies
Lexmark JetPrinter Z25 InkJet Color Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
