Is the heater inside the building and is it venting ok? If the exhaust(I'm assuming this is a natural draft system with a draft hood) is spilling out into the room then the building is in a negative pressure and the unit will cycle on the hi-limit. If this is the case then you need to address the negative pressure issue to resolve the problem.
Was this helpful?
Yes
No
Popular Solutions for Lite On Laars Lite 2 Heaters:
Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
have a problem with a laars boiler Mini-Therm II, the pilot keeps going out. the unit is about 5...
(More)
have a problem with a laars boiler Mini-Therm II, the pilot keeps going out. the unit is about 5 years old and is used for radiant floor heat.
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as...
(More)
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as well. have serviced the boiler and replaced the thermal coupler. the unit is about 10 years old and is used for radiant floor heat
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the...
(More)
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the temp controller?
I am winterizing my Laars Lite2 pool heater and have what may seem to be easy questions but... What...
(More)
I am winterizing my Laars Lite2 pool heater and have what may seem to be easy questions but... What Do I grease the drain plugs with before I put them back after draining heater?. Should it be Silicone based? Also where do I blow the compressed air to dry out heat exchanger?.. Thru the drain plug holes? Thanks
