Question about Acer TravelMate 2300 Notebook
Purple band My laptop has developed a purple band down right hand side about 40mm wide and about 40mm in from the side. How can I fix this? i have same problem,a purple band of 50mm wide running from the top to bottom ,not always but clearly seen when playing video clips
  • 89 Answers
It lloks like the video cable or inverter may be bad. Worst case scenario is the LCD may be bad. Try replacing cable or inverter first.
Posted on Jan 07, 2008
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
Got a purple stripe from the lower edge of the screen center to center. gradient to the middle of screen. like 100 lines wide. any hints THANKS michi m
if it's sharp edged and inline with the pixels, you have a bad green lcd panel. if it's fuzzy and random, you have a burnt light filter. either way, it's an optical engine issue. you can try to go into the case, remove the ribbon cable for the green lcd (unlock the ribbon clip first) and reinsert it and lock it down. if that doesn't work, you'll have to replace it.
Dec 02, 2009 | Sanyo PLC-XP51 Multimedia Projector
Purple Screen on my Canon PowerShot A85 (Canada)
If the purple band does not appear in pictures when you download them on computer, then the problem is a faulty LCD screen or a bad ribbon cable.
If the purple band appears in pictures even when you watch them on a computer, then the problem is a faulty CCD sensor.
In both situations the repair requires complete disassembling and must be done by a technician.
If it is CCD , then Canon may cover the out of warranty repair, call them back and ask again stating that is CCD problem.
You can also get an independent quote on repair here: Repair.
Regards
May 06, 2009 | Canon Cameras
Where is puzzle 120
http://www.wikicheats.com/index.php/Professor_Layton_and_the_Curious_Village_(DS)/Walkthrough#Puzzle_No._078
Go here for all puzzle walkthroughs
Puzzle No. 120 Tap the open manhole above from the Sewers below.
Get the Ball Out! 3: Slide the bottom-right blue block over to the right and drop that lower purple block in the slot with the hole. Now, drop the big yellow block down. Drop the top purple block down one and then reposition the top two blue blocks so they are touching end-to-end directly under the red ball. Raise the left green and the big yellow block up into the center. Slide the bottom-right-most blue block all the way to the left. Drop and slide the other right-hand-side blue block as far left as it can go now. Drop the green block on the right down and into the right-hand nook. Slide one of the top blue blocks to the far right along with the yellow block and the right-hand blue block on the bottom. Drop the red ball all the way down to the bottom row. Move the left-hand green block up into the ball's starting slot and slide the yellow block all the way to the left. Move the bottom-right blue block up and the small purple one that blocks the hole. Now simply put the red ball into the hole.
Jan 04, 2009 | Nintendo Professor Layton & the Curious...
Purple band
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Oct 18, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Purple band
You can try reseating the display cable at both the LCD and systemboard ends. If that doesn't help, you probably will need to replace the LCD panel. Before you do that, try hooking up an external monitor. I'd suspect that you won't get the purple band on it. But, if you do, you may have a video card issue.
Let me know if I can be of more help.
Ron-
Nov 08, 2007 | Acer TravelMate 2434WLMi Notebook
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence
covergence amp ic"S need to be replaced.
Aug 16, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Computers & Internet Logo
285 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
