Lexmark X2350 All-In-One InkJet Printer
Problem for Lexmark X2350 All-In-One InkJet Printer
The on button stays flashing can't copy anything
By rosebudnoahn on Nov 08, 2009
the on button stays flashing can't copy anything
Solution #1
posted on Nov 08, 2009
Not Rated)
JackHeath
Rank: Wiz  Lexmark Expert
Rating: 85%, 239 votes
This is usually an error indicating a mis-installed ink cartridge or a paper jam. It is also possible that it is a bad sensor or a driver issue, but I would re-check everywhere inside the printer first. If that doesn't work...
SOME GENERAL PRINTER TROUBLESHOOTING ADVISE:
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Check for obstruction or paper inside the printer, from behind, and underneath. You may need to remove the paper tray. With the ink, pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expects you to have is not installed. Double check that the ink is correct against the manual or written instructions inside the printer. Not every cartridge that fits in the printer necessarily work.
Was this helpful?
Yes
No
Popular Solutions for Lexmark X2350 All-In-One
Questions and Unsolved Problems for Lexmark X2350 All-In-One
Do you recommend Lexmark X2350 All-In-One InkJet Printer?
Answer
Answer
Lexmark 845 invalid cartridge, how do I reset ink levels?
Answer
looking for drivers for the X2350 to use with windows 7
Answer
paper fails to feed thru while printing. it appears to pull to the right and jams .printing cycle... (More)
Answer
hi my name are ms. james and iam trying to download my printer x5070 lexmark
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Newport, KY
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
