Problem for Washing Machines
Generic problem for all Washing Machines
How do i take the cover of my top loa...
how do i take the cover of my top loader
Clarification Request
Posted by FixinFax on Nov 08, 2009
Make / model ?
Best Solution
posted on Nov 08, 2009
Rank: Guru
Expert
Rating: 96%, 7581 votes
To remove the exterior case of a Whirlpool manufactured top loader, follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To reinstall the washer case, follow these steps:
1. Re-install washer case. With the lid of the washer open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have any questions, please let me know. I hope this helps you.
Comments:
Nov 11, 2009
- If these instructions didn't work, you could have posted back with remarks so that I could attempt to assist you further. A brand name and model number would be a good idea to include with your questions.
Was this helpful?1 person thought this was helpful
Popular Solutions for Washing Machines
Maytag Neptune MAH5500B Front Load Washer
1 Solution
Whirlpool Ultimate Care II LSQ9549L Top Load Washer
1 Solution
Whirlpool Ultimate Care II LSQ9564J Top Load Washer
1 Solution
Questions and Unsolved Problems for Washing Machines
I am looking for the largest front loader washing machine. I do not want a lot of options just...
(More)
I am looking for the largest front loader washing machine. I do not want a lot of options just plain and simple.
Which are the best front load washer and dryers?
it leaves detergent stains on our clothes and the whites look dingy
The OP Information code keeps flashing, but the lid is closed
The washmaschine It stops working in the middle of the cycle and the letters HF is showing on the...
(More)
The washmaschine It stops working in the middle of the cycle and the letters HF is showing on the display, I don't have an owner's manual
