Question about Siemens SpeedStream Modem (4100) (SS4100)
Speed Streem 6520
Greetings...!
I would like to get guide line from you, to fix my Speed Streem modem. By mistake I have disabled the default gateway IP adress. also I have changed the IP address from 192.168.254.254 to 192.168.1.1 later I am not able to access the IP configration page.
And I tried to reset,several times.
I have the Installation CD with me.
Kindly Guide me
With regards
Johnson
+919495033752
vattacattu@gmail.com
  • Anonymous Mar 16, 2008
    need to restet this modem to factor defaults i do not have the disk that came with it do you know where I can download it
You can go to command prompt and type command as in small letter which is "ipconfig /renew" it will reactivate your old active ip address.#
if not go in control panel and right click on connection icon -->properties --then--> general tab -->TCP/IP --> change the ipaddress there. i hope it will help u.
Posted on Jan 26, 2008
How to reset clock on 6520 mpbile
Follow the instructions on the screen to set up your phone and prepare it for use.
  1. Find "Reset all" Press the Navigation key. Select Settings. Select Security. ...
  2. Restore factory default settings. Key in the phone lock code (default is 1234) and press the Navigation key. Press the Navigation key to confirm.
Doro 6520 - Restore factory default settings - Device Guides
https://userguide.vodafone.co.nz/doro/6520...os/basic.../restore-factory-default-settings/.
or go to this link might help.
How to reset clock on 6520 mobile Google Search
Oct 28, 2017 | Computers & Internet
Greetings
ur phone must be reset to factory defaults by mistake.
Aug 29, 2008 | Panasonic KX-TG4500 Phone
I need driver for speed streem 6520 modem. thanks
go to google.com then type Bell:speedstream 6520..you can download the driver.
Sep 19, 2011 | Siemens Computers & Internet
I am using THOMSON TG585v7 and THOMSON TG585n Modems in my workgroup network (more than 15 users.).how to disable internet for some particular users...i am n/w admin..please Help me. Thanks
Before my gateway add is 192.168.3.254 but by mistake i will make factory default so how can i again configure from 192.168.1.254 to 192.168.3.254 plz as soon as possible modem detail thomson gateway speedtouch tg585n
Sep 06, 2009 | Computers & Internet
Comm error 388
Here's some info and possible steps to take. This is from the HP website.
Error 388 for a HP LaserJet 3050
The local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames. If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Disable V.34 on local machine V.34 is the modem protocol used by the product to send faxes. It is the worldwide standard for full-duplex modems sending and receiving data across telephone lines at 1,200 or 2,400 bps. The default setting for V.34 is ON . Follow the steps below to disable V.34 setting.
  1. Press Menu/Enter .
  2. Press the < or > buttons to select Fax Setup , then press Menu/Enter .
  3. Press the < or > buttons to select All Faxes , then press Menu/Enter .
  4. Press the < or > buttons to select V.34 , then press Menu/Enter .
  5. Press the < or > buttons to select OFF , then press Menu/Enter to save the selection.
Hope this helps, samson39
Jul 22, 2009 | HP LaserJet 3050 All-In-One Printer
I have a Bell DSL modem Speed Streem 6520,linksys Wrt160n &16port
How to Set up the Bell DSL modem: http://www.digitalhome.ca/forum/showthread.php?t=97732
Setting up a Linksys WRT160N Wireless Router: http://www.linksysbycisco.com/US/en/support/WRT160N
(Download the Manual from this site)
Setting up a Linksys 16 port switch: There are many different switch models, however if it just your basic switch, you should be able to just plug it in and plug in your computers via RJ45 cables.
If you need any further assistance let me know....
Serge
Apr 09, 2009 | Linksys WRT160N Wireless Router
Siemens Speedstream Modem 6520
hi there... normally you get the Key number .. on the back of the router.. its would be a WEP key or WAP key.
Jul 31, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Usb is not working with vista
here is the link from where u guys can download the windows vista usb driver
http://modems.nokiasiemensnetworks.com.au/USB_WIN_drv_4.9.0.135[1]_1447813.exe
Apr 30, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Voip and speedstream 6520
hi, XBRMann
re 6520 seimens wireless modem
i have DSL internet connection
when the phone call dies i hang up the phone and call again for the same amount of time 3mins and 18 secs
i am using the seimens modem/router with the voip adapter connected via ethernet cable
i have updated the seimens modem/router with the latest firmware from the telstra site E752-AF5-106-71-a056-v1s
lkratzma
Jan 28, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Connecting to internet
Remove the router, connect the phone wire to the modem and the lan to the system, now configure the modem as per the ISP details. This should solve the Problem. the modem itself acts as a router, when you have two routers your default gateway in the lan prorepties should be configured with the ip address of the router which is attached to the phone line. More over the ip add of the routers might be the same as the default is 192.168.1.1.
Because of this you might be getting the error message.
Jan 02, 2008 | Nintendo Wii Console
Siemens SpeedStream Modem (4100) (SS4100) Logo
419 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
