Question about Canon PowerShot A560 Digital Camera
Dc power source (battery)
When ever i put ON my camera it directly give me a prompt stating "change the batteries" on the LCD screen with dark background. When this prompt appears sometime lens remains open and st does not response.
till date i didn't use rechargeable batteries. i've been using Alkaline battery only.
so is it a software problem or hardware problem? comments pls
is it because of battery? comments pls.
or is it because of battery's host contacts? comments pls.
  • tedee Jan 06, 2008
    comments pls.........
  • Canon Master
  • 4,738 Answers
Yes, you should be using rechargeable NiMH batteries. Alkaline batteries just don't have the power to stand up to digital cameras for more than a few pictures. Look for power ratings on the NiMH batteries of at least 2,500 mah.
Posted on Jan 08, 2008
Hi, i have a canon 500d trying to fix, thanks, when i put battery in even with power off, or power on, the blue lamp right of LCD stays on (does not blink), and no power on to the camera other than th
Check the HDMI, mini-USB, and SD card connectors for damage. The DC/DC board is part of the front board and it comes with the battery compartment. Check front and back of board for liquid damage and impact. Check SD card slot for damage to the contacts.
Nov 28, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
I got problem with my Canon powershot sx100 IS camera. It is giving only 4-15 pics with new alkaline batteries after that LCD screen will become dark on the screen change batteries message will appear. can...
You can use rechargable cells with high current( mA) rating. So try and use any rechargeble cells with above 2000mA . Also you can use a rechargeable adapter externally to charge these cells.
Aug 17, 2011 | Canon PowerShot SX100 IS Digital Camera
My batteries dont last long. I put in new batteries and after only maybe one hour of use i get the change battery prompt.
Battery life really depends on a lot of things the amount of use you are giving the LCD screen, the temperature you are using the camera in meaning the colder it is the shorter the battery life, not all batteries are created equal and most "no name" brands are lacking in staying power. Your camera is able to work with rechargeable batteries Ni-MH AA's will last at least three times the length of the Alkaline types. You can buy a set of four rechargeable batteries with their charger fairly inexpensively and will pay for themselves very quickly because you can keep charging them.
Dec 27, 2010 | Canon PowerShot A1100 IS Digital Camera
My camera will not turn on!
Try to power it using battery and then, DC source. If its not powering, check battery contacts and clean them. If you have a volt measure unit, measure the volts from the DC source and compare the results with the values from the DC unit, also measure the battery and see its status. If you cant solve it in theis basic way, try to go to a professional repair center for a detailed analyzis. Cheers
Dec 09, 2010 | Sony Cyber-Shot DSC-P41 Digital Camera
There is a flashing number inside the screen that I cannot remove, and my pictures are not coming out as they used to.,.they are very dark,,.how do I remove this flashing number it says 91:01
Just follow the steps below to remove the error message.
Turn off camera.
Remove the battery or the power supply.
Turn the switch to CAMERA for about 30 sec.
Turn the switch to OFF.
Install the battery or power supply.
Turn the switch to MEMORY.
Open the LCD cover and press the RESET button .
You will be prompt to adjust date/time. Do take some pictures.
Hope this helps.
Thanks for using Fixya.
Do rate the solution.
Dec 14, 2009 | Sony Cybershot S650 Digital Camera
Put new batteries in. Power light comes on.
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common for LCD.
Good luck
Sep 30, 2009 | VistaQuest DV-7 DV Camcorder
Dark and blurry
It will clear instantly with a fresh battery.
The viewfinder screen has an LCD overlay and even when the camera is switched off the screen uses a small amount of power. When the batteries are flat the screen is unpowered, the crystals in the LCD align randomly to both darken and blur the viewfinder image.
Please don't forget to rate my answer.
Jul 18, 2009 | Nikon N65 35mm SLR Camera
Camera would not turn on
try removing the battery for 24 hours and allow the battery to charge for that long as well unless you charge the battery in the camera with a docking station then just leave it out also take a good look at the lcd when you try and turn it on see if the image is really dark but their is still a image. one this that I have noticed while working on casio is that a lens error can cause the lcd to be very dark and you can barley see a image but it is there so it causes you to thing the camera is dead. If you do see a image then the problem lies inside and needs to be serviced but if you don't then it lies in the power source. ie battery or power circuit of the camera. after the battery shows charged have it tested with a ohm meter it can help determine if it is a good battery. you can have it checked sometimes at radio shack or a place called batteries plus if you do not have one. I hope this helps out I know it can be frustrating but it happens. good luck.
Mar 04, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Canon PowerShot A560 Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
