Question about Sharp AR-5316 Advanced Digital Imager Copier
PAPER JAM I have a panasoncic fax machine. It jams exactly at 2 and half page always. If 2 pages are faxed no problem. Whats the solution?
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Did not specify where it is jamming?
is the paper size correct?
is the paper under the metal tabs in the tray?
is it jamming in the fuser?
is the fuser OK, if constant jamming in fuser then replace.
Posted on Jan 07, 2008
My fax is having a problem feeding pages through the document feeder, it doesn't always grad the page, and if it doesn't get it, it acts like it has a paper jam, what is causing this?
Open the document feeder. Inside you will find a grey feed roller. Cleaning this roller with a cloth dampened with water will help with these paper jams in the document feeder.
Sep 29, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Reciveing a papeer jam ussually on any fax with a
Try to clean the pick ADF with a piece of soft cloth wet with alcohol
Apr 06, 2010 | Brother IntelliFAX 4100 Laser Fax
How do I remove a paper jam? The paper is
The following is general advice that applies to removing paper jams in most printers, copiers, etc.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab.
Always remove jammed paper by pulling it in the direction of normal travel only. Don't try to pull it out against the direction that it entered the printer. Sometimes rollers inside the machine have a knob (usually coloured green or orange) that can be used to manually wind the page through the printer or fax. Always turn in direction of arrow indicated only.
After removing page, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test
Feb 04, 2010 | Brother IntelliFAX 4100 Laser Fax
Incoming faxes stuck in memory, how do I print them. Prior to this the faxes were coming through, but half printing then jamming, so press start and that peice of paper would come out then the next go in...
This answer maybe a little late for you but for anyone else tring to print fax stored in memory:
1. Press Menu - Fax Functions will display
2. Press 2 - Print report will display
3. Press Enter - Last Transact will display
4. Press 7 - Reprint Faxes will display printed the pages
5. Press Enter
This will print all faxes in memory. Press Stop when you have printed the pages you need.
You can print fax log (Press 2 after step 3) to see what is in memory
Oct 01, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Jammed frequecy
Open the printer panel and check for friction. Better still, contact a service technician near you.
Jun 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Fax memory says full. how do you get them(Panasonic KX-FG2451)I haven't been able to receive faxes, don't know if this would effect it.
The memory is full of received documents due to a
lack of recording paper, a lack of ink film or a
recording paper jam. Install paper (page 13), install
ink film (page 11) or remove the jammed paper
(page 63).
the entire manual here
Apr 17, 2009 | Panasonic KX-FG2451 Fax
Jam paper inside
believe it or not, a bad/faulty drum unit can cause this. or possibly the feed rollers just needing cleaned. it really helps on jam problems when you can print just 1 page and let us know exactly where that paper stops at.
good luck,
Jan 28, 2009 | Brother IntelliFax-2820 Laser Fax
UX A460 Paper Jam during fax reception how do I prinmt from the memory
open the machine and clear the paper jam and then closed.The machine will start printing again.
Oct 17, 2007 | Sharp UX 108 Roll paper Thermal Fax
Sharp AR-5316 Advanced Digital Imager Copier Logo
127 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
