Just installed. I selected heavy duty cycle. The time on the washer when it started was like an hour...
(More)
Just installed. I selected heavy duty cycle. The time on the washer when it started was like an hour and 40 minutes. Is there a way to change the time of the cycle? Please advise?
maytag mah2400 door leaking. grey rubber inner door seal looks misshapen at bottom, with no visible...
(More)
maytag mah2400 door leaking. grey rubber inner door seal looks misshapen at bottom, with no visible tears or holes. there is an odd shaped hole on bottom of the door itself, below area fits inside of grey seal when the door is closed, and there was a "callous" of hard plastic like material along the front/bottom of door (above the hole, which appears to be part of the door, but not sure) . water leaks most during rinse cycle, and comes out in small stream in 3 or 4 places- the most water comes out when the water is filling tub and rinsing. I did a small load with just two bath mats and a lot of water was on the floor after that load. a larger load resulted in less water leaking out.
I need a diagram so I can take my maytag mah 24 front loader apart correctly. I have the dreaded nd...
(More)
I need a diagram so I can take my maytag mah 24 front loader apart correctly. I have the dreaded nd code, so I just know I have something stuck in the pump. ifruci@yahoo.com
