Duet Dryer control panel will not respond or turn on, tech said I need a new dial because the old one is slipping. He said the dryer is acting funny because the dial is slipping and it is getting stuck in between cycles. I put new dial on dryer and now the control panel will not turn on. How do I get the panel to respond or reset it?
My dryer knob gets stuck. The dryer will run for hours, once for 8 when I was gone one day. It stays...
(More)
My dryer knob gets stuck. The dryer will run for hours, once for 8 when I was gone one day. It stays in the same spot, not rotating at all. How do I fix this?
Whirlpool dyer modle # GEW9868KL0 will not work, have replaced the board but still nothing. We have...
(More)
Whirlpool dyer modle # GEW9868KL0 will not work, have replaced the board but still nothing. We have correct voltage, but none of the controls work. HELP
Hi my in-laws have a whirlpool LGP6848AWO gas dryer that does not run. The drum motor does turn on...
(More)
Hi my in-laws have a whirlpool LGP6848AWO gas dryer that does not run. The drum motor does turn on and the gas flame does not fire up. It basically does nothing, however, I can hear the timer running and I can hear the start relay energize or click when I hit it and I can hear that the timer stops and the start relay de-energize when I open the door. I've check input voltages, voltage across the start relay seems and across the thermo switches 120vac. Btw the buzzer (part of the tan wire system) seems dead, yet could be normal. Otherwise everything seems to check out. The motor has a block on it with five wires and I do have 120v, yet not sure where it should be. It's difficult to work on, since the front panel also holds the drum in place to run, so I pulled the belt, yet it's still not all that easy. Since its 17 years old, I'm inclined to tell them to get a new one, of course my wife wants me to fix it for them. Any ideas?
