Question about JVC AV-20120 TV
JVC - AV-G21T
Can anyboby please assist in getting or show me to a place where I can get a wiring diagram /pc board layout for the above model TV.
  • 579 Answers
There are a number of very affordable places to download pdf files of the service manuals for that set.
servicemanuals.net
manualsparadise.com
user-service-manuals.com
Hope ya fix it!
Posted on Jan 06, 2008
Jvc 36 inch av-36890
remove the AC cord from the back of the tv for 3 mins and reconnect
hope this wrks
Jul 17, 2008 | JVC AV-36950 TV
I have a JVC HDTV model AV-65WP74, i had my tv on overnight, woke up this morning i found the colors on the tv kind of funny and the tv is also showing double images. Please help. What to do?
The convergence ICs have failed. You can get the JVC AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com which has the ICs and resistors plus the CD with detailed repair instructions.
Nov 08, 2010 | JVC AV-65WP74 Rear Projection Television
Where can i get the diagram for my TV to fix the convergence, i have a JVC AV-48WP74
You do not need a diagram, I can tell you all that is involved--it entails getting the board with the parts out and replacing both chips and any bad resisters.
See attached photos: they are of the board that needs to be removed.
This is a easy set to get at the parts and they are soldered in, so you need to be able to solder etc.
Let me know and I will be happy to assist here.
IF the pictures or this information told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH.
Sep 19, 2010 | JVC AV-56WP74 56" Rear Projection...
JVC AV-65WP74the picture projectscuved in the middle of the scren
This kind of picture problem is due to failure of convergence out ICs, please replace convergence out ICs in tv to get it fixed.
If you are handy with electronics stuff repair and can replace parts in circuit board with proper tools then can replace above said ICs by yourself or ask local tv tech to repair your tv.
Thanks.
Mar 15, 2010 | JVC AV-65WP74 Rear Projection Television
Need wire diagram jvc av-48wp74
http://www.nodevice.com/manual/newmans/jvcupdate/AV-48WP74PDFpdf/get52302.html#
That should have everything you need.
Feb 05, 2009 | JVC AV-48WP74 48" Rear Projection...
I have a jvc av48wp30 tv and need a wire diagram
Looking the convergence board from the side of the resistors (The chips will be behind the resistors), you have from de left to right:
1.5 ohms, 150ohms, 220ohms, 2.2ohms, 3.3 ohms, 220ohms, 1.8ohms, 220ohms, 150ohms, 150ohms, 1.5ohms, and dispose horizontal in relation of the other resistors (the one near to the Ic is 2.2ohms and the other is 220ohms).
Hope this helps...
Feb 02, 2009 | JVC AV-48WP74 48" Rear Projection...
Tv -jvc modele : av-g21t horizontal out put transistor burned after seconds
check the yoke or change the crystal number 503(blue/ orange)if still damage the Horzntal transistor , flyback is defected.
Nov 16, 2008 | Televison & Video
Please help me fix my tv
You will need 2 new convergence ICs STK392-110 also the 1.8 ohm resistor and the pico fuse usually burn with that model. the ICs are located on the small board located behind the speaker grille and access panel in front. Easy repair go to the following link and you can get replacement ICs and any other part you need. And they provide installation instructions as well as free on line instant meassaging for all customers when they do thier actual repair. Heres the link.
http://servicemanuals.vstore.ca/
Apr 08, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-27S33 27" Picture
I've found several bad solder joints on the neck board of my JVC 32' leading to the exact same issues as yours. Inspect the Driver resistor solder on the neck board.
Dec 10, 2007 | JVC AV-27S33 27" TV
JVC AV-20120 TV Logo
335 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
