Konica Minolta 5430DL optional second tray - print dialogue will allow only plain paper - is there a way to use gloss or thick setting from the optional lower feed unit? I want to print legal-size glossy.
Comments:
Nov 08, 2009
- Going to the printer web interface, using printer Adminstrator password, I don't find any option for 2d tray settings. Or, under Control Panel-Printers-Run as Adminitrator-Properties = same thing. I am missing something. Is there something else I should install? or reinstall? Thanks for your help!
This needs to be setup through the computer using the printer properties, not through the printer. You will need to be the local admin to make the changes. You may also have to go under advance and manual specify the tray and component types. The printer will not allow you to set options for trays and components that are not enabled or detected. Let me know if you need a step-by-step.
Comments:
Nov 08, 2009
- You should have a component chooser under the printer properties, I can get you a screen shot tomorrow. I'm not at work today.
Nov 09, 2009
- These do not auto-detect well. Make sure they are manually set.
Then make sure you select paper type on the paper tab.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
2d tray is recognized, print dialogue allows me to click Glossy, but then says CONFLICT and resets to plain paper.Ideas?
" - michaeluce
Popular Solutions for Konica Minolta magicolor 2530
Printer was working fine an hour ago, now it says Yellow Toner Not INstalled. I removed Yellow...
(More)
Printer was working fine an hour ago, now it says Yellow Toner Not INstalled. I removed Yellow toner, cleaned all contacts on both the toner and seat, no help. Then rotated whole magazine by hand several times, no help. Machine was making allot of noise thru the whole process. Machine was turned off when top was opened and toners manipulated. Cannot get printer to work, get the 'RED' zig zag thing in the lower right corner.
I have a magicolor 2530DL and I've changed all cartridges including the drum.. still reads end of...
(More)
I have a magicolor 2530DL and I've changed all cartridges including the drum.. still reads end of life. What do I do to reset it?
