Bosch Axxis WFL 2090 front load washer: I find water in the drum twelve to twenty-four hours after I...
(More)
Bosch Axxis WFL 2090 front load washer: I find water in the drum twelve to twenty-four hours after I last finished washing a load of clothes. I had left the door open overnight to let it air dry. Closed it in the morning and then in the evening there is an inch of water in the drum. The drain pump has been cleaned. Problem seems to be intermittent.
I need to replace the door seal on a Bosch Axxis WFL 2060 and and need any tips/advice on doing...
(More)
I need to replace the door seal on a Bosch Axxis WFL 2060 and and need any tips/advice on doing this.
Drum doesnt always turn through full cycle. It appears that the slightest out of balance causes the...
(More)
Drum doesnt always turn through full cycle. It appears that the slightest out of balance causes the cycle not to complete. Is there a way to adjust this? It will complete if there is nothing in it just fine so it is not the Motor, belt is in good shape and tight.
