2 piece aggitator with fabric softener dispencer, top part is loose and spinning separate from bottom. How do you remove the top portion tosee if it can be fixed
Pull off the softener cup
Remove the cap underneath
Remove the bolt
Pull up on the agitator to remove....if it is stuck, drizzle some liquid wrench into the bolt area
its not cycling thru the washes its a cabrio model 2 years old will go to wash cycle and wont...
(More)
its not cycling thru the washes its a cabrio model 2 years old will go to wash cycle and wont complete it where can i find a manuel for this online too..
When I first start a load I will get the f1 error and have to restart the load 3-4 times to get it...
(More)
When I first start a load I will get the f1 error and have to restart the load 3-4 times to get it to go. Then it always gets an f 1 error when it reaches 19 minutes left in the cycle. Any suggestions?
what can be done to stop f1 error message problem every time you turn it on it gives an f1 error...
(More)
what can be done to stop f1 error message problem every time you turn it on it gives an f1 error message after being turned on and off about ten times it will work and then
my whirlpool cabrio as been sitting outside covered for 8 months. i just hooked it up again and now...
(More)
my whirlpool cabrio as been sitting outside covered for 8 months. i just hooked it up again and now it will not do a complete cycle. it starts out on 42 minutes and about 5 minutes later it done. can you please help?
