When I press the menu button my camera scrolls repeatedly through the menu screens and the arrow keys and OK button are non-responsive. I reinstalled the firmware with no improvement so am thinking it may be a hardware problem...
Go to your menu button on your remote scroll down to the features by using the down arrow button on the remote.press OK on features menu. Scroll with the down arrow on the remote to the the CC Closed caption option in the features menu press OK. Press CC on or CC off and press OK then Exit button.
Turn the Hannspree-brand monitor on using its remote, then press "Menu." Press and scroll the down arrow button to highlight "Setting." Press the right arrow button to enter the "Setting" menu.
Press and scroll the down arrow button to highlight "Aspect."
Press and scroll the right arrow button to change the aspect ratio from "Auto" to "Full," "Normal," Panorama" or "Zoom," depending on the type of image that you want to see on the screen.
Press "OK" on the remote control. Press "Menu" twice to exit the menu settings.
hope it helps
You can delete photos from your SX130 IS in two ways:
To Delete Photos Individually:
Press Playback Mode button (looks like a play button and is located on the top right on the LCD-side of your camera)
The last image you took will appear on the LCD screen.
Use the Left & Right arrow keys or turn scroll wheel to cycle through your images
Once you find an image you want to delete, press the Trash button. The image will be erased.
Press the Playback Mode button or the FUNC/SET buttons to exit when done
To Delete ALL Photos
Press the MENU button (bottom right button on LCD-side of camera) to bring up the Menu screen
On the Playback tab (Looks like a Play button icon), use the arrow buttons or turn scroll wheel to scroll down to Erase. Press the FUNC/SET button.
You now have three options Select, Select Range, and All images. Select will allow you to delete individual images, Select Range will allow you to select a series of images, and All images will delete all images from memory. This last one is the option we are looking for.
Use the arrow keys or scroll wheel to choose All images
Use the arrow key or scroll wheel to select OK when the Erase confirmation screen pops up.
To clear memory of MF 4350d do the following
Press MENU and then #
You will enter into service mode.
Scroll using any of the arrow keys and press OK for CLEAR DATA
Again using arrow keys scroll and select MEMORY CLEAR press OK.
You can go to: www.sonystyle.com for support to download manuals. On you camera press the menu button. Use the control button arrow keys to scroll over to the wrench icon. Then continue to scroll over to page 2. Scroll down to the language bar using the cotrol button down arrow key. When the language bar highlights press the center control button to execute the selection. A menu will appear that you can scroll up/down with the control button arrow key to highlight your language. Then press the center control button to execute the selection.
In order to reset the camera settings to its default values you need to do the following:
-Press the MENU button
-Use the left or right arrow keys to select the Settings menu (its icon looks like a wrench and hammer)
-Use the up or down arrow keys to scroll to the choice that says "Reset ALL..."
-Press the "Func./Set" button to confirm your choice.
This will reset the camera to its factory default settings.
If your camera is giving you a `E91` error on screen it could be a faulty flash module and need replacing at a Sony Service Center. Contact your dealer for info.
But, before you do that try steps 1 and 2 below.
Here is some things you can try:
1. If it is only a setting you can select the `green` camera for auto shooting and then press the `UP arrow key until the flash sign is shown on the screen. The screen will also say `Flash On`. Take a picture to see if it works.
If not proceed to `2` below.
2. Press the `Menu` button.
First select the `Green` camera on the selection knob.
Scroll with the right arrow to the little toolbox picture.
Once in the setup menu scroll down to the toolbox picture with a 1 under neath.
Press the right arrow arrow and then scroll to the `Intialize` option.
Press the right button and select `OK`.
Press the middle button on the arrow selector.
Camera now wants to know if you are sure, select ok.
You will now have to enter the date again and setup any `Program` settings you might want on the camera.
Now take the camera into a dark room - as it is now on `Flash Auto` and test to see if the flash works.
If none of these helped you, you can take the camera to a repair agent and get it fixed. I have replaced numerous of the flash modules at approximately a quarter of the cost of the camera.
Resetting the base & handset/s on a BT Freelance XD5500:
Hold the Find button on the base unit until you get a double beep then tap the Find button 7 times. On the handset: remove a battery hold the menu key and refit the battery screen says SW VERSION press up arrow key until screen shows REGISTER CLEAR press menu press menu again and wait for OK to appear remove a battery and refit
Registering the XD5500 handset. Then register the handset to the base as follows: Hold Find button on base unit until you get two beeps On handset: Press menu Scroll to register Press menu Scroll to Register Base Press menu Press 1 Wait When it says PIN ? Enter 0 0 0 0 (four zeros) and press menu.
Note: If you have more than one handset then repeat registering the handset to the base for each subsequent handset/phone.
If this procedure fails to solve the issue, then you have a unit with a fault and if it is less than a year since purchase the retailer should change it for you.
Here are the steps to set up a static IP on your printer.
With the printer displaying 'Ready to Print', press the [Up] or [Down] arrow button on the Control Panel and select [Printer Setup] on the Display Screen, and then press the [OK] button.
Press the [Up] or [Down] arrow button to select [Connection Setup], and then press the [OK] button.
Press the [Up] or [Down] arrow button to select [Network Setup], and then press the [OK] button.
Press the [Up] or [Down] arrow button to select [TCP/IP Setup], and then press the [OK] button.
If necessary, press the [Up] or [Down] arrow button to select [TCP/IP], and then press the [OK] button to select [On].
If necessary, press the [Up] or [Down] arrow button to select [DHCP/BOOTP], and then press the [OK] button to select [Off].
Press the [Up] or [Down] arrow button to select [TCP/IP Address], and then press the [OK] button.
Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the address.
Press the [OK] button to accept and move to the next three digits. Repeat until the required IP Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
Press the [Up] or [Down] arrow to select [TCP/IP Network], and then press the [OK] button.
Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the network mask.
Press the [OK] button to accept and move to the next three digits. Repeat until the required Network Mask is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
Press the [Up] or [Down] arrow to select [TCP/IP Gateway], and then press the [OK] button.
Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the Gateway Address.
Press the [OK] button to accept and move to the next three digits. Repeat until the required Gateway Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
Press the [Up] or [Down] arrow to select [Exit], and then press the [OK] button.
To DELETE ALL the pictures:
- Press on the PLAY mode button (to view pictures)
- Press MENU
- Keep on scrolling until you see PLAYBACK menu tab
- Scroll down to DELETE option
- Use arrow keys to select ALL
- Press MENU/OK to confirm
