Question about Compaq Refurbished 7 EVO N410C DVD/CD-RW COMBO DRIVE (BULK PLEASE CONTACT SALES) (261741933) CD-ROM Drive
Trouble with my cd rom drive
My cd / dvd drive is not working like it should and i am getting frustrated with it can you help me please
  • FAISAL_372 Jul 05, 2008
    HY EVERY ONE CAN U PLEASE HELP ME WITH
    HL-DT-ST CD-ROM GCR-8480B
    I NEED A DRIVER FOR IT URGENTLY
    THANX.
  • Anonymous Oct 17, 2008
    I am looking for any updated drivers for the Toshiba XM-6502B
Hello sir post me solution it is very helpful
Posted on Oct 30, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Its it now working totally or its working slow?
if it is not working then check the setup that is is detected.
if it is slow then there are 2 options
1. change the DATA BUS (DATA CABLE)
2. clean the lense using lens cleaner if it is in warenty if it isnt then you can open it and then can clean the lens using a soft cloth with cleaning liquid or as I use NAIL POLISH REMOVER ;)
Posted on Jan 06, 2008
I would like to watch a movie on my computer, so i put it in the dvd slot and closed it and nothing happened. PLEASE HELP, I'm getting so frustrated.
try to install some codec like Klite codec full or download VLC player. you can play it manualy if you browse the dvd drive and search the video files
Aug 22, 2011 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
Hi I'm Tony from the Philippines and I have a Compaq presario f756nr notebook pc (to be exact), i want to reformat my laptop and the problem i am facing now is that when i try to use my cd/dvd rom drive to...
Hi Tony,
Thanks for the details you have mentioned. The steps you have taken are correct and if the System/ hardware is ok, it should boot from CD Drive. Whenever i have faced such an issue, i always started afresh to check each hardware (CD, DVD, ROM, Hard Disk, Cables, Connections etc) and most of the times the issue was optical drive or CD/DVDs.
So, I recommend that make sure that the CD/DVD ROM is functioning properly. When the system is set to boot from CD/DVD, it must try to read CD/DVD after power on. It is indicated by spinning of the optical drive and blinking CD ROM LED. If there is a bootable CD in the drive, it should boot. You may try to boot the system through DOS bootable CD. Also, if you still have the OS on your system, you may check the CD ROM through windows.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP Compaq Presario F756NR Notebook
CD ROM DRIVE/DVD ROM DRIVE PROBLEM!
it is infecetd by viruses.. scan for viruses..
please vote for me...im sure this will solve your problem...
Sep 14, 2009 | Computers & Internet
DVD-RW burn drive is being recognized as CD-rom drive; it's not the laser, because I went through the trouble of purchasing a brand new DVD burner drive and it's doing the same exact thing. Can anybody...
If you have not done so, under device manager, remove the dvd rom (cd-rom) from the hardware list, Use the CD install disk that come with your DVD-ROM, install the drivers and software, then reboot your pc and let it install the new hardware detected. This should get you going.
Good Luck
C2Solutions
Aug 18, 2009 | Computers & Internet
DVD DRIVE/CD-WRITER
GO TO CONTROL PANNEL
SYSTEMS
HARDWARE
DEVICE MANAGER
CLICK DEVICE MANAGER(WINDOW)
EXPAND CD /DVD ROM DRIVES
RIGHT CLICK ON SELECTED DVD/CD DRIVE
SELECT PROPERTIES
1.SELCT DRIVER ( CLICK UPDATE DRIVER)
2.CHECK DVD REGION CODE.
3.UN-INSTALL DRIVER
4. REINSTALL DRIVER AGAIN(AFTER STEP 3)
OR
IN DEVICE MANAGER RIGHT CLIVK DVDCD ROM DRIVE
UN-INSTALL DRIVER
OK
REBOOT COMPUTER
ADD HARDWARE(CONTROL PANNEL)
IT WILL PROPMPT FOR INSTALLATION OF DRIVER
SAY OK.
PROCEED WITH WINDOW INSTRUCTIONS
DVD/CD ROM DRIVER WILL GET INSTALLED AFRESH.
HOPE IT WORKS.
Jul 01, 2008 | Computers & Internet
DVD Drive Troubles
This can be due to the reason that the certain cd roms cannot be read by your drive. please insert and check other brand cd roms...if they run then the cd rom u r using cannot be read by ur Cd.dvdw DVD drive
Mar 08, 2008 | Computers & Internet
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
Having a trouble with my DVD-ROM - IBM ThinkPad T42
Internal the pickup assy. (the laser) there are three components that read the discs, one for DVD one for CD and one for the DVD-ROM its likely that the DVD-ROM laser has gone out. Take the drive out and get the part number and look it up online on ebay or the like :-)
Sep 13, 2007 | IBM ThinkPad DVD_ROM Ultrabay (73p3270)...
Computers & Internet Logo
69 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
