Magnavox 42 inch LCD TV
My magnavox will change the source and channel when I am using hte TV. For example, if I am watching a DVD in AV1, the TV will automatically change the source to AV2 or to random channels. Is this problem common?
  • smithro Jan 07, 2008
    I have a Magnavox 26" LCD/DVD combo player with exactly the same problem. I'm combing the web now looking to see if anyone has the same problem and found this post. Would appreciate any findings. I have in the meantime tried using different video sources, different electrical outlets but all to no avail.
  • jaaknolan Jan 26, 2009
    I have the same problem. If i am watching in AV1 it keeps switching to TV, and the channel changes.
I was having the same problem. On my tv it was caused by a loose or faulty interface chip. I solved this on my television by opening the case and unplugging the circuit board at the top center where the menu and channel buttons are located. I've been running the tv for about a week and have had no more problems.
Posted on Oct 18, 2010
Looking for an owner's manual for a Magnavox 28MD304V/F7 28-Inch 720p 60Hz LED TV-DVD Combo [ASIN: B00KVLZSTG]
Free Magnavox Flat Panel Television User Manuals ... > ... > Magnavox > TV and Video Magnavox
Products 1 - 50 of 128 - Magnavox OWNER'S MANUAL LCD TV Monitor 15MF200V/37. Pages: 0 ... Magnavox User Guide LCD TV With DVD Player 17MD250V.
Jan 14, 2016 | Magnavox Televison & Video
Did you check your cabling on the video input to the TV? I would try replacing the cables first. If that doesnt work I would try using a different source for the video than what you are using now. Do you have a seperate dvd or bluray player or even another cable box that has the same outputs as the source you currently cannot see? If so try using another one and if it still doesn't work then the culprit most likely lies within the TV.
Oct 11, 2013 | Philips Magnavox 42MF521D/37 Television
I can't get the VCR mode off the TV screen in order to watch TV.
try looking for either "source" button on the remote or ""input" choice. also you can try using the channel changing buttons, sometimes you can get out of vcr mode by just going up or down on the channel selector
Mar 16, 2011 | Philips Magnavox 20MC4304 20 in....
My audio and my picture are on two different channels like i can see the movei on av1 but i cant hear it but if i turn to av2 i can hear it but not see it
sir, check the cable which is connects TV and DVD player Audio Video cable ... both should locate at AV1 port in TV and DVD... else AV2
Mar 04, 2011 | Philips Magnavox 52MF437S/37 52 in. LCD TV
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Change input source for philips magnavox
use the up/down channel until you get to the input you have connected. You did not say you had a remote so i am using the standard fix for this.
Apr 28, 2009 | Philips 19PR19 19" TV
Magnavox, channel buttons cycle through sources
You need to reprogram your TV if you do not have a cable box or satellite box, otherwise those are going to be the only channels that the unit will pick up. If you do have a cable box or satellite box, just hit 0-3 or 0-4 if you are using a coaxial wire. If no box is present, you can just go into the menu and hit autoprogram - select cable for direct cable from wall, and antenna for antenna. Note: this particular TV is going to need a box in another 5 weeks due to the DTV transition, so my solution will only carry you for another few weeks.
-Tha Mp3 Doctor
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Magnavox 42MF531D black screen
Common issue I have come across when using any TV as a PC monitor. Best workaround i found is just dont change inputs or reboot the PC and the tv will pick it back up.
Sep 01, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Hooking up a magnavox MWD7006 DVD player to a APEX TV
honey and guest: connections: Red, white, and yellow composite from out of cable/sat box to in of this dvd, and then a 2nd red , white and yellow cable from out of this player to in on television. Every television calls the correct channel something different - make note of where you plug the r,y,w cables to TV -- it may be labelled video1, video 2, av1, av2, input1, ext 1, etc. Turn tv to correct input/av/source/video channel. Call 1-800-605-8610 for further assistance.
Jan 13, 2008 | Philips Magnavox MWD7006 DVD Player
Televison & Video Logo
225 people viewed this question
Top Televison & Video Experts
