Question about Dryers
WHIRLPOOL DRYER My Whirlpool dryer gets too hot then cuts off.I found a fuse laying at the bottom of it but i don't know where it goes. Could that have anything to do with it?
Instructions on how to install the belt
Posted on May 02, 2008
Sensoring stays on and dryer will not work on Cabrio dryer
there is a fuse in the back of the dryer next to the bottom on the left hand side it has wires plugged into it cost $11.00 to fix don't call whirlpool they don't have a clue
Sep 05, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a Whirlpool Duet Dryer model WED9400SU0. The thermal fuse went out last week. I replaced the fuse and fully cleaned the vent and internals of the dryer as well as the full path to the outside of...
to the touch the clothing should not be very hot, i see where ya have cleaned the vents(good job!!)
on occasion i have found where a fabric softner sheet has clung to the face of the lint filter housing,look at the plastic housing around the area of where the lint filter goes and see if something is stuck to it restricting the air flow into the filter housing
Jul 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My dryer stopped drying our clothes in the past. I replaced the fuse and problems solved. Now same problem replaced the fuse and it heats up then goes out. I cleaned out the hose and dryer everything...
Is it blowing hot air out the vent?. I've seen something like pencils , lint or about anything clog the fan and won't let it turn. The vent must be clean going to the outside of the house. You can take the vent tube off at the dryer and see if it helps if it does out side vent might be cloged.
The operating thermostat might not be cutting off power to heating coil soon enough and getting hot enough to blow fuse. Check all thermostats and any one time cutoffs a one time fuse. Don't know what type dryer or model number you have. When you ask for help always give the name and model or your machine because they are different.Hope this helps.
Aug 16, 2010 | Whirlpool Dryers
Belt and tensioner issues on a Whirlpool LEB6300LWO have a new belt the tensioner was just laying in the bottom of the compartment think i know where it goes but doesn't add up cause you cant just cut the...
Hi, I wouldn't say you are way off, unless your expectations are way hi. Most average joe's or jane's don't work on dryer's everyday, so some reason needs to be considered. I'm currently on my iphone and not my home computer so I can't attach an illustration to guide you on how to thread the belt through the pulley/idler however, if you go to youtube and type in whirlpool dryer belt repair it should yield you many helpful videos on "how to" just what you need. Hope you found this info helpful and if so please rate it's helpfulness or leave a testimony...or both. Thank you for coming to "fixya" for your repair tips. Let me know if I can assist you further, and good luck. Macmarkus :)
Mar 15, 2010 | Whirlpool Dryers
Whirlpool Cabrio Dryer Wont go past sensing light when I press start. The door is tightly closed and the filter is clean. It just won't even try to start it just just beeps once.
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
Nov 04, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
LER4634EQ2 whirlpool electric dryer. heating element,thermal cut-off, and high limit are all getting continuity, but heating element still will not heat up.
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Oct 09, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Dryer works but no hot air
Hello, if it's an electric dryer and you have absolutely no hot air, then it's either the heating element or the thermal cut-off, most likely.
The thermal cut-off is the fuse on the element's housing.
Check both for continuity. Good luck :)
Please feel free to keep emailing me if you'd like.
Nov 18, 2008 | Whirlpool LEW0050P Electric Dryer
There is a thermal fuse its location depends on the dryer if the filter is on the top then you have to take off the back panel and check the white fuse. If the filter is inside the dryer you have to take off the bottom panel. a flathead screw driver for the 2 clips the check the white fuse behind the lint trap (where the filter goes).
Oct 29, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
135 people viewed this question
Top Dryers Experts
