i acquired a beautful 6' fiberglass eljer garden tub that had never been installed before. i understand about setting it, and building the deck surround to install the faucet, etc. but what about the drain? the tub only has a center drain hole, no overflow hole. do i buy an 'L'-shaped drain with an overflow and cut a hole in the tub to accomodate that? can you tell i know nothing about this sort of stuff? i have a porcher deck mount kit with a 'telephone' shower, but it didn't come with the supply lines or drain. can you help? thanks, callie
Tub overflows are not required in all states but I highly recommend drilling the hole and installing the proper waste and overflow drain I recommend the Gerber brand and also when you set the tub you need to set it in a light concrete for stability I use great stuff foam for setting tubs 2 cans spray on floor and set and level tub tub will never wobble or move
My shower water pressure has been decreasing and fluctuating. Have new (6 months old) Kohler...
(More)
My shower water pressure has been decreasing and fluctuating. Have new (6 months old) Kohler Thermostatic valve in remodeled master shower. There is a main shower head and a shower handle with separate volume control handles. When both are turned on they both had good pressure when first installed. I have cleaned all screens. Pressure is good when ONLY cold water is on.
I purchased a 1 1/2" bathtub drain Lift & Turn. I'm having difficulty removing the...
(More)
I purchased a 1 1/2" bathtub drain Lift & Turn. I'm having difficulty removing the drain flange. Do I turn it counter clockwise or clockwise to remove. The cross at the bottom of the flange was broken sometime in the past of which I've no knowledge of what happened. Any advise would be appreciated. Thank You! P. Skala
Franke faucet FF200 series. Leaks coming off the sprayer cord under the sink. Cord seems to be damp...
(More)
Franke faucet FF200 series. Leaks coming off the sprayer cord under the sink. Cord seems to be damp all the way up to the nozzel. Leaks overnight even though the faucet is turned off. HELP!
Who fixes Culligan water softeners and equipment in Sonoma County besides James Fisher and son in...
(More)
Who fixes Culligan water softeners and equipment in Sonoma County besides James Fisher and son in Santa Rosa??
my tub stop will not come out. I believe it is a moen. I can unscrew the top but then nothing. There...
(More)
my tub stop will not come out. I believe it is a moen. I can unscrew the top but then nothing. There isn't a slot for a screwdriver and I can not unscrew it to the right as I would assume. Thanks for any help
