Question about Sony Playstation 3 (PS3) Console
No sound from digital out on PS3 using optical cable
I can not get my PS3 software version 2.0 to output sound to my Sony STR-D845 receiver through its optical output.I have tried changing the settings numerous times and also changing from bitstream to PCM, nothing seems to work. Cable and receiver work fine with other DVD players.
Any help will be greatly appreciated.
  • 3 more comments
  • pacopepe Jan 06, 2008
    Yes, the optical cable does glow, so there is a signal. I also tried using another optical input on the receiver and still did not work....
  • pacopepe Jan 07, 2008
    I have tried the TOSLINK cable with both DVD input and MD/DAT inputs. Also I have selected the input manually and still nothing.
    I tried the power switch trick and got no results.
    I'll try the firmware update next.
    I do appreciate your help very much. I just hope I don't need to get a new receiver.
    The firmware update 2.10 apparently fixed the problem. Thank you very much for your help.
  • cecilenator Dec 05, 2008
    007 blue ray plays digital sound though out. Narina only the menu and previews in digital and the movie is not. Any thoughts?
  • Anonymous Mar 27, 2014
    No sound from stereo hooked up to sony strk670p
  • 319 Answers
Does the end of the optical cable glow red when hooked up to your PS3 while the PS 3 is powered on? Look at it without the cable plugged into the STR-D845.
Posted on Jan 06, 2008
  • 2 more comments
  • Brian Berndt
    Brian Berndt Jan 06, 2008
    OK next, please tell me which of the 3 digital inputs are you using to for the TOSLINK cable (optical cable) MD/DAT IN TV/SAT IN or DVD/LD IN?
  • Brian Berndt
    Also, please be sure that you do not have the STR-D845 set to AUTO INPUT SELECT. You need to manually select where the input is coming from.
  • Brian Berndt
    Well I am STILL TRYING to help with your frustration! I will include a link that may be helpful. I believe that if you have considered the earlier posts, and nothing works, follow the problem along in this post:
    You may need an updated firmware. There is a link in this post:
    For an update, if you are not online with your PS3.
    Also, please consider changing my rating, as I am completely voluntary in helping, no pay whatsoever! Good Luck with your problem, and keep me updated thru this post.
    I have PS3 and Sony receiver, and I do not have any problems, so I am hopeful that you merely have a software issue.
    One other trick that was mentioned was to use the power switch a the back of the PS3 to shut down the unit, then try to restart after you have made changes to your audio setup in PS3.
  • Brian Berndt
    Brian Berndt Jan 07, 2008
    Are you sure that you changed your settings in your PS3 correctly? I think that you have to go thru the menu completely to save it after entry.
    I would check that again, also make sure you have selected a compatible setting (in the PS3 menu for Settings--Audio), I think I have the 5.1 dolby checked.
    New Friend:
In the sound settings on the ps3 test select multipal or if not always in sound settings on the ps3 configure the optical audio source and configure tested and working myself
Posted on Oct 15, 2013
Why is center channel dead?
Sony STR-K840P Sound center speaker - Questions - Fixya > ... > Sony > Sony STR-K840P
... sound from center channel during viewing, or during speaker level test- all other speakers emit tone, but center is dead. I have optical digital cable and hdmi ...
Sony STR-K840P Sound center channel - Questions - Fixya > ... > Sony > Sony STR-K840P
Sony STR-DB940 pulled back from the brink - Page 2 - Badcaps ... > ... > Audio Equipment Discussion
Jan 01, 2016 | Sony STR-K840P
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
Select [Audio Output Settings].
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
Optical digital cable connection ?
It only works through DVD setting
Jun 20, 2009 | Sony STR-DE545 Receiver
Getting the best out of my Sony STR DE-475
Yes, it would downgrade.
Simply run an HDMI cable to the LCD from the DVD player. Now, use the digital audio output of the DVD player to run to the receiver. I know the Sony has an optical input which i recommend over the coaxial input as the optical cable doesnt waste any energy as a medium transferring sound since its only light.
Mar 29, 2009 | Sony STR-DE475 Receiver
NO AUDIO/set up problems
For this Sony, you have to use separate audio cable(s). Either optical in BD or Digital Audio in DVD (single coaxial cable will do the trick) I bet the display says UNLOCK. I had the same problem, very dumb.
Good day!
Jan 19, 2009 | Sony STR-DG510 Receiver
Audio decoding
You will need to tell the PS3 to use the optical cable for digital output in its setup, as well as tell your amp to use the optical cable as the input for whichever 'source' you wish to have associated with the PS3.
Nov 22, 2008 | Sony Playstation 3 (PS3) Console
Sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Nov 16, 2008 | Sony STR-DB930 Receiver
I am using an HDMI cable on my STR-DG710 and get no sound
A lot of devices like PS3, HD DVD Players, Cable boxes, etc., require you to define on the setup menu if sound will be coming out of the HDMI cable or not. Most of these devices can be set to HDMI Auto, but not all of them do.
I currently have both my Blu-ray and HD DVD player outputting both video and sound through my HDMI into my STR-DG710. Both devices are setup to output sound through the HDMI.
But like the other person on here posted, it you have a DVI to HDMI cable, you won't be getting sound. The only device that will output sound from a DVI to HDMI are select computer graphics adapters like the GeForce 9800 GT series video cards, and even not all of those will have this feature.
Hope this helps.
Jun 23, 2008 | Sony STR-DG510 DTV Receiver
Rear speakers not working on STR-K740P
The only way your surround sound will work is if you have either the coaxial or fiber optic digital hookups attached to a PS3/Blueray/DVD/Cable box/Satellite box that have digital sound outputs. If you are just using the 1970's version of the red/white audio cables that is stero only.
Mar 02, 2008 | Sony STR-DE625
Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
Jan 02, 2008 | Sony STR-DG510 Receiver
Sony Playstation 3 (PS3) Console Logo
1,187 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
