Question about Proview PL926WBi 19" LCD Monitor
Connecting a monitor to a different modem
I have a Proview LCD 19" monitor that i need to connect to a Compaq modem..I got the right cable hookup but it won't work.What do I do ?
    Problem Solver:
  • 14 Answers
Is there a vga port on the modem? if so make sure the inputs to the modem are wired correctly, just keep in mind the monitor is there for you to see the video not to create one.
Posted on Jan 08, 2008
My laptop screen got wet now it has a dul screen and a dark area
I always start with seeing if when connecting an external monitor to the Laptops VGA output is the same or different to what you see when just via the Laptops screen. Reason is so that can narrow down to JUST Laptop screen or graphics chip, maybe even OR connection at cable either end, Motherboad or Screen.
Is the Laptop turning on alright i.e. no frying, I assume it has dried out from when it got wet. localised to screen only or possibly inside of Laptop....Lights up with power, fan spins hard drive spins, right? If so try an external monitor.
Feb 20, 2013 | Proview PL913S 19" Flat Panel LCD Monitor
My proview pl 926wbi comes on with a black screen and a no signal message then shuts off.
Check that the cable is firmly connected and plugged into the right connection on the computer. Make sure that the monitor is reading from the right input, (i.e. if it's a blue connection it should be set to VGA/Analog, if white then it should be DVI/Digital) or at least set to Automatic.
This can be configured on the monitor by pressing its' Menu button.
Feb 28, 2011 | Proview PL926WBi 19" LCD Monitor
Fujitsu Siemens 19 W LCD monitor: no image
Temporarily connect a different monitor to your computer, to see if your video-card is the problem.
Temporarilyh connect your monitor to a different computer (desktop/laptop), to see if your monitor is the problem.
Try a different "data" cable between your monitor and your video-output port.
Jun 12, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Monitor is black and white
In my experience this is usually a fault in the video cable (either the cable itself or a bent pin). I would say unplug the cable from both the PC and the Monitor and plug it back in, taking care to be sure it is connected securely on both sides. If you have a spare video cable (or borrow one) I would try connecting that as well.
Jun 05, 2010 | Proview PL913B 19" Flat Panel LCD Monitor
White screen comes on when powered on
**Caution. Hazardous voltages inside.
This could be a loose connector inside the monitor connecting the LCD panel. A careful check of these delicate connectors (open, reinsert the cable, close the connector) or remove and reconnect the plugs may fix it. White screen means there is no drive to the LCD panel AT ALL.
Mar 30, 2010 | Proview PL926WBi 19" LCD Monitor
19" proview LCD monitor light and signal
How old is this thing? Mine is about 4 or 5 years old... junk it!
Mar 25, 2009 | Proview PL926WBi 19" LCD Monitor
Flashing Monitor
Sounds like either  a loose connection or a short in the cable going from the monitor to your computer.  Try disconnecting the monitor from the computer, and plugging it back in again.  If this doesn't resolve the issue, try bending the cable in different places.  If this causes the monitor to correct itself, even just for a little bit, it is a bad cable.  You can take it off from the monitor and the computer, take it to a store that sells cables, and get a new one.
May 29, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 19inch LCD MA982k model 900p
You are on the right track. Sometimes the ribbon cables will look fine but the wire inside the insulation is broken and will result in intermittant problems. Definately check the cable first and repair or replace. It is best to meter the cable while not connected to avoid false readings through other components. Should be a relatively easy repair.
Jan 03, 2008 | Proview PL926WBi 19" LCD Monitor
Lcd monitor looks like pic negative
make sure the cables are pushed in all the way and tighten. On pick that is out of place can distort color correction. also try reseting the monitor to factory settings.
Jul 22, 2007 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
