Can you provide the exact Make, Model and Kenmore model number? Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines. Without knowing the model number, I'd have to guess that what you are looking at is a method of keeping drained water from flowing back into the washer, also known as a check valve or a one way valve. .
Go to: SearsPartsDirect.com They show breakout drawings of each sub-assembly that also list the part numbers for ordering. The ball does not seem to be a likely component.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 22422 Top Load Washer
The plastic agitator is secure to the center steel shaft, but the transmission or gearbox is not...
(More)
The plastic agitator is secure to the center steel shaft, but the transmission or gearbox is not producing any activity
I moved my Kenmore 70 series washer and noticed on the washer pan shavings and grease. Still works...
(More)
I moved my Kenmore 70 series washer and noticed on the washer pan shavings and grease. Still works fine. What do I need to fix/replace before this turns into a big problem?
